What should I do? Want new suspension but not harsh polyurethane ride?
Old Oct 3, 2003 | 12:08 AM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Forgive me, I don't hang around the suspension board much, so I don't know if this is covered a lot.
I'm really wanting to overhaul my suspension bushings, tie rods, ball joints, etc. Everybody recommends the Polyurethane stuff, but it makes for a harsh ride, correct? I know it makes up in the handling department, but for me that isnt terribly important right now. The car handles really well already and has all the crappy stock rubber stuff in place.
Is there an alternative to polyurethane that will improve ride quality? I know it won't be as good in the handling department. That's ok. It's a mainly street driven car and I'm tired of that harsh ride! I guess you guys can understand I don't want to trade for a more harsh ride with better handling .
Please make suggestions.......Thanks!
Old Oct 3, 2003 | 12:52 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You can go with 1LE spec bushings but I think the cost wouldn't justify that. Why not go ahead and upgrade to poly bushings and just go with some softer springs and shocks? Say go to "RS" springs instead of "Z28" springs?
Ed
Old Oct 3, 2003 | 11:20 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I haven't noticed any extra harshness by installing the poly. But then again, people said the ES trans mount caused extra vibration, and I don't feel that either.
My car's ride quality went from harsh to "less harsh"... the bushings and springs were original +255,000 mile units. Front struts were from '96 (probably 100,000 on 'em) and rear shocks were air shocks. I thought the ride would be harder when I was done, but it wasn't... I guess I had been "falling into" bumps and holes and ripples, where as now, the suspension can actually handle them, and keep the car level.
Old Oct 3, 2003 | 02:44 PM
jamesbob02's Avatar
Car: 92 Z28
Don't poly bushings squeak and bind and stuff? I don't want a new suspension that souhds old. That's one of the reasons I'm replacing my stuff anyway.
Old Oct 3, 2003 | 03:17 PM
Speedemon171's Avatar
Car: Camaro
Engine: 350 SBC
Transmission: Five speed
Anything short of spherical rod ends will bind, and those are way too harsh for what you are looking for. Also, as long as poly bushings are properly greased, they will not squeak.
Old Oct 3, 2003 | 04:19 PM
Kandied91z's Avatar
they are definately a little harder and you can hear the road noise alot more in the car as well as vabration in some instances. i eventually replaced most of mine with good rubber pieces and i'm very happy with it.
Old Oct 3, 2003 | 04:29 PM
jamesbob02's Avatar
Car: 92 Z28
Kandied,
Where did you get your good rubber pieces? I think thats what I'm going to do.
Old Oct 3, 2003 | 04:38 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: What should I do? Want new suspension but not harsh polyurethane ride?
Replace it with stock rubber bushings. . . . You have answered your own question. Use Moog.
RBob.
Old Oct 3, 2003 | 04:40 PM
Kandied91z's Avatar
yep very nice pieces from moog and they work just as well as the poly.....may not hold up as long obviously but for a street car they are much nicer.
Old Oct 3, 2003 | 05:03 PM
jamesbob02's Avatar
Car: 92 Z28
Is there some part numbers you can give me or a package deal to look for? Thanks.
Old Oct 3, 2003 | 05:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
No squeaks from mine yet... see https://www.thirdgen.org/techbb2/sho...hreadid=186491
Old Oct 4, 2003 | 07:52 AM
Morley's Avatar
PST poly-Graphite (no squeak) or their "stock" replacement bushing kits.
Old Oct 4, 2003 | 11:35 AM
jamesbob02's Avatar
Car: 92 Z28
I had a hard time locating Moog parts to buy. Also, I could use some part numbers if you guys have them. I pretty much want to rebuild the front suspension/steering assembly short of changing the antisway bar and the shocks/springs (for now).
Old Oct 6, 2003 | 11:20 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
I put the PST Polygraphite stuff in mine and no squeeks. Its got graphite impregnated in the bushings and they act as a lubricant. I was happy I did too, even with 47,500 mi on the car, the stock rubber sway bar bushings were seriously chewed up. Anyone know the life expectancy of the polygraphite stuff?
If you get the regular polyurethane stuff you'll have to lube it yourself. Don't know if the cost difference is worth it, I went straight to PST w/o looking at the plain polyurethane stuff.
Anthony T.
1990 white TA harptop 305ci/A4
Goumba's 1990 TA
Old Oct 6, 2003 | 03:01 PM
jamesbob02's Avatar
Car: 92 Z28
That all sounds really great, but I still don't want the harder ride. My ride is harsh enough as it is, so I think I'm going to do with the rubber stuff. I still need a package or part numbers to look for though! Thanks.
Old Oct 7, 2003 | 12:09 AM
Morley's Avatar
http://www.p-s-t.com/
Old Oct 7, 2003 | 12:44 AM
jamesbob02's Avatar
Car: 92 Z28
Has anybody bought the standard front end kit from there? It doesnt say what its made of or who manufactures it, but I assume its good rubber instead of the Polygraphite of the other set.
Old Oct 7, 2003 | 12:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Guys, the PST "polygraphite" bushings are made by Energy Suspension. Just do a <a href="search.php?s="><img src="images/top_search.gif" alt="Search" border="0"></a> ...
Old Oct 7, 2003 | 01:09 AM
jamesbob02's Avatar
Car: 92 Z28
If you're talking to me, I asked about the non-polygraphite set.
Old Oct 7, 2003 | 01:23 AM
Morley's Avatar
Made from standard OEM rubber, just like stock.
Old Oct 7, 2003 | 01:30 AM
jamesbob02's Avatar
Car: 92 Z28
Ok that's cool. I'd like to hear from anybody who's bought it, though. Thanks.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
