what noise is this?!
Old Oct 12, 2003 | 06:38 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
new parts and new problems
yesterday i spent about 9 hours working on the beast, installing the LCA's, relocation brackets, eibach springs, tokico illumina shocks. I also had to chop up my flowmaster cat back kit and welded it backtogether, so that took a good chunk of time.
anyway..... the car handles great, but now i have a humming/whining sound that gets louder the faster i go, it doesn't change with changing rpms, just with mph's. I have adjustable poly lca's and also installed poly end link bushings for the rear sway bar. I'm guessing its a drivetrain thing, but i don't get why it started with the mods i did yesterday. Any suggestions?
edit: I was looking at the car and I think that my rear might not be centered, i was in a rush last night and didn't check the length of the lca's after installation or the wheel spacing from side to side. Would that account for a new noise?
Old Oct 12, 2003 | 07:25 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Your alignment is most likely off if you bought eibachs pro or sportline kit. Probably toed out and slightly cambered in now that your car is lowered some. I guess it could also be your rear end due to the change in pinion angle.
Old Oct 12, 2003 | 12:15 PM
mgilorma's Avatar
Car: 90 RS
actually i guess i should specify that i only did the back half of the car last night, I still have do the springs and struts on the front. so, I'm guessing it's something with the drivetrain, but the thing is i got the pro kit, and the old springs were pretty shot, so it only lowered the car like half an inch anyway.
Old Oct 12, 2003 | 07:16 PM
Redbird's Avatar
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
Check to see if something is rubbing the driveshaft, or that maybe one of the wheels isn't rubbing. I can't imagine that the LCA's being off would effect the pinion angle that much.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
