anybody using adjustable spring spacers for the rear?
Old Oct 14, 2003 | 07:11 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
Not sure if I'll need it but I want to see who else is using them and how well they worked.
Old Oct 14, 2003 | 07:36 PM
JERRYWHO's Avatar
Global west has them also
Link http://www.globalwest.net/camaro93.h...justment%20kit
Jerry
Old Oct 14, 2003 | 08:08 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Ground Control makes them also. Haven't seen anyone around here running them tho.
Old Oct 14, 2003 | 09:36 PM
Engine: 3.6L
I have generic afco 200# 5.5x11" pigtail sprongs and want to be able to swap springs (different rates) and adjust height as necessary. I'll also need so rear end limiting staps so if for some reason my rear drops too much the springs don't pop out.
The standard price for the adjusters is around $38 each as compared to $240 for the GW piece. I imagine the GC ones are similar to the generic adjusters.
Is there any place local I can pickup axle limiting straps? or perhaps an off-road shop should have them available.
Old Oct 14, 2003 | 11:55 PM
CrazyHawaiian's Avatar
Car: too many ...
I'm using the ground control units with 1/2 height Suspension Specialists springs (700#/150#). Works really good but the only thing I'm worried about is the possibility of the spring/spring pertch becomming unseated if you hit a big bump and the tires lift off the ground (this would happen if you are running springs that are too stiff), so I'm thinking about welding the spring pertches to the car. Never actually had this happen, but one of the things I'm paranoid about since I'm running 1/2 height springs on very crappy roads.
From my experiences with spring pertches, they are all over priced. If you look at how they are made, I'm positive you could assemble your own for under $30 a set. I paid full price from ground control for one set, but thats the last time. I learned my lesson after looking at the products out there for stock cars.
Old Oct 15, 2003 | 07:47 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I'm using Ground Controls adjusters front and back also. I like the front adjusters however the back ones do give me second thoughts. I'm running 850 fronts and 175 rears, 9.5" free length springs. PFlyer is also using this same combo.
Here's a pic of the rear adjuster:
I'll post some pics of the front later today.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
