NO BREAKS !!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 14, 2003 | 08:18 AM
confucius101's Avatar
NO BRAKES !!!!!!!!!!!!!!!!!!!!!!!!
while driving into work this morning i relized (right as i tried to slow down for a sharp turn) that it's time to work on my breaks
especial seen as how as of 822 this morning i have none %^)
so what upgrades if any can i do for under the 300 i have in my pocket
91 3.1 firebird
front disk rear drum
I've been searching all morning
but all i get is the le1 @ ls1 info
Old Oct 14, 2003 | 08:20 AM
ede's Avatar
ede
with your limited budget i'd say better quality pads/shoes and make sure the rest of the system is good
Old Oct 14, 2003 | 09:06 AM
yea thats what i was thinking......
would you all recomend any one brand over the others ?????
Old Oct 14, 2003 | 11:11 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
I switched from Perf Friction Carbon Metallics (Crap) to Bendix Titanium Metallics (p/n MKD154) and found a huge improvement. I actually think my brakes are 'good' now. (disk/drum)
Old Oct 14, 2003 | 11:36 AM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
You first need to make sure your master cylinder and booster are working correctly. Did a swap for those recently, not too bad.
Old Oct 14, 2003 | 12:07 PM
Steve89GTA's Avatar
You should speak to your boss about not having a break. In Canada, we get a mandatory break every 4 hours of work.
Unless of course you're talking about 'brakes'.
Old Oct 14, 2003 | 06:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL, Steve!
1. Yes, quality pads. I've used Bendix MKD-154's since I got my car in 1994, before they were "titanium coated", and they work great. ~$30.
2. Replace all your brake hoses with new ones. Two front, one rear. ~$50
3. New rotors- your originals are probably paper thin, and aren't dissipating heat well anymore. Heat = no brakes! If your wheel bearings don't show heat damage or scoring, you can re-use them; or buy new- they're cheap enough. Pack them with synthetic grease. ~$5 front grease seals, ~$5 tube of synthetic. Wild guesses: ~$100/rotor set, ~$30/bearings.
4. Buy a $20 Mityvac and a few bottles of brake fluid. Before you change your hoses, flush the system with new brake fluid. Brake fluid is hydroscopic; it absorbs fluid. Old brake fluid = absorbed a lot of water = lowered boiling point = no brakes. Procedure basically is, raise car, remove tires, siphon old fluid out of m/c, leave a bit in the bottom holes, wipe sides of m/c clean with a rag (not paper towel), fill m/c with new fluid. Work at one wheel at a time, start at rear, loosen bleeder screw, attach mityvac, suck old fluid out until mityvac tubes show new fluid. Have friend keep watch on m/c to make sure BOTH reservoirs stay full with new fluid. When you pull new fluid thru, shut bleeder screw, and move to next rear wheel. Then go to your front wheels. Don't touch the brake pedal during all of this and you won't get air in the system. After flushing, then replace your brake hoses. http://www.eastwoodcompany.com (do a quick-search for Mityvac) or http://www.toolparadise.com (choose Mityvac from drop-down list) if you can't find a mityvac locally... they have a few different kinds, from an expensive do-it-all master kit to a basic brake bleeder. ~$50
5. Replace rear drum shoes, and inspect wheel cylinders; replace cylinders if necessary.
Old Oct 15, 2003 | 08:45 AM
LMAO thanks steve you just made my morning
ok guy's thanks for the info.......
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
