What sizes will fit on a stock 16in Rim
Old Oct 14, 2003 | 07:26 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I have a 91 RS with the suspension package, they are the same wheels as on the z-28's. I was wondering how wide of a tire could I go on these rims, right now I have 235/55/R16's. Would a 255 fit? What would be the losses/gains to this, what about the sidewall height, losses/gains to higher or lower, what size range will fit, does anyone know?
Old Oct 14, 2003 | 07:46 PM
Cleaner13's Avatar
not sure if its a big help or not but I got a 1989 TTA and it has 305/40/16s on the rear
Old Oct 14, 2003 | 07:50 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
What size are your rims, do you have them on the stock ones?
Old Oct 14, 2003 | 07:51 PM
Cleaner13's Avatar
yes the rims are stock the 16X8s, no rubbing etc
Old Oct 15, 2003 | 12:16 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Isn't that a bit too big on that rim?? Do you have any pics of it? My thought is that the sidewall bulges a LOT...and the sidewall flex would hinder cornering...
Old Oct 15, 2003 | 12:31 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I finally found it by searching, I think 255 is the biggest I should go with the stock rims.
Thanks.
Old Oct 15, 2003 | 12:58 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I just installed 255-50-16s on my stock rims and they fit perfectly. 305 is NOT a recommended tire size for an 8" rim.
Old Oct 15, 2003 | 07:30 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Wheel manufacturers and distributors can tell you which tires will safely fit on what wheels. The tires come with a specification of how wide a wheel is necessary to be fitted. You can fit 275/50/16's safely with most tires out there on a 16x8. 305 is too large for an 8" rim. Going to large hurts performance and causes rolling of the sidewall.
Old Oct 15, 2003 | 09:07 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
this is what i use....i like it.
Old Oct 15, 2003 | 10:53 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
You use the 255 or the 305? I was thinking I will probably look for a set of good 255 tires.
Jeremys87
Jul 14, 2022 09:08 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Randomtask2
Aug 13, 2015 01:57 AM
knight72
Aug 10, 2015 09:32 PM
Exxon Limited
Aug 9, 2015 08:13 PM
