If you had to pick one suspesion part to do..
Old Oct 15, 2003 | 03:31 AM
bigals87z28's Avatar
Car: Check The Sig
what would it be? Just one part. i.e. LCA's, torque arm, panhard bar, stb & wonderbar... which one would give me the best benifit for both turning and traction?
Old Oct 15, 2003 | 06:17 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
why just one? the real secret to suspension is making it all function together, and work as a system. that being said, the torque arm is one of the best mods. if you don't already have them sub-frames will also make a HUGE change, and should be the first mod done to these cars. springs and/or shocks/struts can also make a dramatic change in the car. ack, there are so many things.
Old Oct 15, 2003 | 11:42 AM
Spdfrk1990's Avatar
Well if there was just one the first 1 i would get would be a wonder bar.
Old Oct 15, 2003 | 12:02 PM
Marc 85Z28's Avatar
Neither of those you listed. I know you've heard it before, but subframe connectors will make one of the most dramatic differences in not just handling, but all around performance. I was amazed at how much of a difference they made with my handling, rattles, and overall feel of the car. Everyone insists on subframes for a reason!
Old Oct 15, 2003 | 12:16 PM
MdFormula350's Avatar
i would say lower control arms if i had to chose.
Old Oct 15, 2003 | 12:56 PM
Car: Check The Sig
so far all sounding good to me. I wana do my own testing, and i would like to see what would give me the best gain in performance and fell of the car. Subframes are a great idea and are on my list, but thats something i cant do myself, where i could do LCA's, torque arm, etc.. myself. I still want to hear some more ideas.
Old Oct 15, 2003 | 01:08 PM
v8unleashed's Avatar
Yes.
Old Oct 15, 2003 | 02:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You haven't changed anything yet?
If not, my #1 recommendation is polyurethane end links for both anti-sway bars. Part # ENS-9-8117G from http://www.summitracing.com . Big improvement in cornering for only 28 bux!
<a href="https://www.thirdgen.org/techbb2/showthread.php?s=&threadid=184552">I'd list others</a>, but you just asked for one.
Old Oct 15, 2003 | 05:40 PM
laiky's Avatar
premium shocks and struts, illuminas or koni's
Old Oct 15, 2003 | 06:13 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Why not??? Get a set of bolt in ones (i like the ones tds has im getting a set this winter) and bolt em in in your garage. They will be fine bolted on and if you ever want that added bit of insurance you can just get em welded up shouldnt cost more then 50 bucks max either way there are enough people that never weld them and are fine. Get some sfc's just about everyone on here will swear by them as your first chassis/suspension mod.
Old Oct 15, 2003 | 06:29 PM
conlinj's Avatar
Lower control arms
Old Oct 15, 2003 | 07:11 PM
10.90streetcar's Avatar
If you never do another thing to your car, Put SFC on it.
Here is a list of mods to my suspension and it cuts 1.39 60ft times.
Also this is the order that I would do them in.
SFC
Boxed LCA
Relocation brackets
Hal 12 way adj. shocks on rear
Bolt In 9" rear from Moser
Slicks
Rear anti Roll Bar
Everything else on the suspension is stock, Including the Torque Arm, Springs and EVERYTHING in the front end.
HERE is a link to my car in action
Old Oct 16, 2003 | 08:57 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Al: You've got T-tops, right?
SFCs period. Then bushings and shocks. You won't believe the difference.
Ed
Old Oct 16, 2003 | 07:25 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
DAMPERS
Shocks and struts. End of story. No other single part will make as big of a difference in handling.
Konis are my recommendation. Reds if you want a nice ride. Sports if you want a real performance ride.
Old Oct 17, 2003 | 11:01 PM
jeremy178's Avatar
Car: '89 Camaro RS
SFC's.
Old Oct 17, 2003 | 11:24 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ahhh i forget if i saw the post on this board or camaroz28.com (or maybe its already in this thread and im blind???). Someone said they did all of these supension goodies but didnt do sfcs and their car handled sooo well it bent the chassis.....get sfc's
Old Oct 18, 2003 | 07:08 AM
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
A set of tires like Hoosier A3S03's.
Old Oct 18, 2003 | 04:43 PM
CaysE's Avatar
subframe connectors. that should be the first mod anyone should get. and if you're only getting one mod, get them. get them welded. and never worry about body flex ever again. any other suspension mod you do relies on the strength of the body and frame, so go get those SFCs.
After that, just go with whatever your cash allows or as needs arise. get LCAs, a wonderbar, strut tower brace, springs, shocks & struts, panhard rod, sway bars, bushings & endlinks, torque arm, BLAH BLAH BLAH... I mean the list is huge.
Old Oct 19, 2003 | 02:08 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
One item only...for turning and Traction? Good Shocks without a doubt. Koni's preferred. Should be first item on a build list.
Old Oct 19, 2003 | 07:26 PM
SgtSkip's Avatar
SFC's fer sher...
Old Oct 19, 2003 | 08:18 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Take ANY car- doesn't matter, even a yugo- Put a good set of roadrace shocks AND a good set of tires- It will handle better than any other upgrade you can buy.
Too many people settle with medium grade performance shocks and tires instead of putting there money where it counts. I'll give an example- Stock brakes and top of the line street tires will stop a car FASTER than big brakes and cheap tires.
You ask for one suspension upgrade? Like Chickenman said, and I'll second- A good set of roadrace shocks- I too only run Koni for best over the counter performance.
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
