is rubbing a prob with 17 x 9's?
Old Oct 16, 2003 | 01:40 PM
onebluemcm's Avatar
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
I posted this in the appearance board already - couldn't decide which board is more appropriate....
Is this likely to be an issue for me? Not sure what rolling stock I'll be using, but with proper spacers up front and 17 x 9's (going on an 89 IROC with factory 15's....) do I need to expect major rubbing problems?
Who has experience with like-sized wheels on third gen camaros?
Please pitch in, thanks
Kevin
Old Oct 16, 2003 | 01:45 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I have 98 SS rims on my car and with the 2" spacers my rims dont rub any. Well...atcually it did a little but that was full lock. And you should atcually never be in complete lock of your steering system. So it should be just fine for normal and competitive driving.
Old Oct 16, 2003 | 02:56 PM
Marc 85Z28's Avatar
Same here, exactly
Old Oct 16, 2003 | 03:39 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I do not rub with my 17x9's either, even at full lock and hard cornering. This is with 275/40/ZR17 out back and 245/45/ZR17 up front.
Old Oct 16, 2003 | 03:47 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Re: is rubbing a prob with 17 x 9's?
Originally posted by onebluemcm
Is this likely to be an issue for me? do I need to expect major rubbing problems?
Kevin
Nope- just maintain stock backspacing. I have '00 10 spoke SS wheels on my 91 RS. With 1.5" backspacing (7 - 1.5 = 5.5) no problems are encountered. I run 245 45 17s all around.
S-D
Old Oct 16, 2003 | 03:53 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Got any pics of the stance of the car? Those rear tires have quite a bit more sidewall would like to see what it looks like
Old Oct 16, 2003 | 05:30 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Here ya go. This view kinda shows the general stance of the car but also shows the rear tire. There are plenty more pics on my site if you would like to see more.
Old Oct 16, 2003 | 07:11 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I've been running 17x9.5 with some 275/40/17 Yokohama decibals all the way around, with minimal rubbing up front.
Old Oct 16, 2003 | 08:08 PM
killsupraman's Avatar
I run joung bloed racing wheels 17x10 up front, 17x11 in the rear and 285 40 zr17 all the way around. No problems during regular or aggressive driving. Close though. They do touch the side ground effects at lock, but just enough to clean the dirt off.
Old Oct 16, 2003 | 08:21 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
That is a monster wheel and tire combo for up front. What springs are you using?
Old Oct 16, 2003 | 08:34 PM
I am just using the stock springs for now... I am not sure of this, but my car seems to ride about an inch lower than most coupes, not sure if it is the extra weight of the convertible or what. But any how, I intend on converting to a coil over soon.
Old Oct 16, 2003 | 09:32 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Eibach Prokit with 17 x 9.5 firehawk rims and 275/40 KDWs on all four corners - very slight rubbing at the front after I thrashed it round an autox course. Not enough to worry about.
Old Oct 16, 2003 | 09:49 PM
CobraKilla92Z's Avatar
Transmission: M6
I have 17x9.5 inch wheels with 275/40/17s all around. I rubbed with stock ride height, so I cut the inner fender some.
Then I lowered the car 2inches and rubbed like hell with 2 and 1/4 inch spacers.
Now I have the spacers, Baer 13" Track Kit which moves the spindle out about 0.40 of and inch with 2" inch drop springs, and tubular front control arms and I finally don't rub anymore, but it's still close. My tire sits flush with my fender but doesn't stick out.
I find it hard to believe that nobody else is rubbing with this setup, but if not then good for ya'll. Hell even my rears rub too, but I just gotta get back there and play around with the panhard rod.
Old Oct 16, 2003 | 10:11 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
I had to put 5/16 spacers on the front because one of the wheels just barely touched the tie rod end. The rims I have were designed for Brembo or Baer brakes or whatever came on the slp firehawks and as you said they make the front a bit wider.
MrPackstin
Oct 25, 2017 08:09 PM
Veaceonee
Sep 29, 2016 08:15 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
