Rear Sway bar idea
Old Oct 19, 2003 | 10:26 PM
laiky's Avatar
Rear Sway bar idea
Anybody ever consider reversing the mounting of the rear sway bar to reduce unsprung weight? What i mean is mounting the center of the bar to the chassis and the ends to the rear? I don't know if there is anyway to fit it that way but i think its worth the unsprung weight reduction
Old Oct 20, 2003 | 01:16 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
It is a good thought- You are correct that the trouble is fitting it.
You could go to a frame mount Coleman torsion bar with arms dropping down to the axle. However-
1) the size bar and arm lengths would have to be calculated properly for the right balance of tension
2) the panhard ros and brace would have to be moved. I know how I could engineer this, but it would involve moving the fuel cell to the rear seat area and incaging it from the drivers cockpit. Then add a j-bar stup in the rear in place of the panhard.
If I ever go full race with this car- which I doubt (Have one already) thats what I'd do.I have already then wasted alot of money on parts that were intended on just being a street use car.
Then we are talking Penske remote-reservoir coilovers, and an aluminum quickchange rearend to go with it.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
