Replace right front brake line
Old Oct 26, 2003 | 09:21 AM
Cam84358's Avatar
Car: 84 Camaro
Engine: v6 to v8 swap 357ci chevy
Transmission: TCI Turbo 350
When replacing the front brake hoses on my 84 Camaro I twisted
the line off at the nut on the right side.It was froze up bad.Now I need to replace the line.The line runs under the engine .I bent the old line getting it out.Whats the best way to do this.?If you drop the exhaust Y pipe can you get the brake line in there?Route it a different way?Bend my own line or order some from classic tube or Inline tube?
Old Oct 26, 2003 | 01:01 PM
ede's Avatar
ede
bend your own, doesn't have to be a perfect match to work, or look good. buy a good bender and a piece of tube with the correct fittings
Old Oct 26, 2003 | 03:31 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You could just go to a scrap yard and pull a line off of one of those cars.
Ed
Old Oct 28, 2003 | 07:57 PM
Cam84358's Avatar
Car: 84 Camaro
Thanks for info.I tried soaking that connection with liquid wrench,friends say I should of tried some heat on it.Thats what happens when you get in a hurry.
Old Oct 29, 2003 | 04:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's the pain with those tube nuts... even if you took your time with it, there's no guarantee it won't snap.
http://www.classictube.com (and I think a few other companies) sell our brake lines in Stainless Steel!! After snapping quite a few tube nuts on my rear disc axle, when I finally fix that posi and put that axle back on, I'm putting the SS line kit on it.
Old Nov 1, 2003 | 10:35 AM
Cam84358's Avatar
Car: 84 Camaro
Yep,Stainless steel would look good ,but more expensive.Ive heard that stainless steel is nearly impossible to double flare without special equipment.I bought some stainless steel fuel line one time and tried to flare it ,couldnt do it.
Old Nov 4, 2003 | 11:11 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Use the proper tools for the job
When doing brake, fuel, or tranny coolant lines. You should use line wrenches. If you dont have them get them. Their like 35 bucks for Crafstmans and like 10 bucks for Harbor Freight. I have the HF's. Get em and life will be GRAND.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
