some ? on chasis parts
Old Oct 29, 2003 | 07:12 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys im going to install spohn lcas with relocate brackets and a panhard bar along will there subframe connectors will this lower my ets with the lil mods i have?also i heard there is a brand of sfc's that are difrent from were the sphon ones weld on so it strengtens the chasis even more what brand is that?
Old Oct 29, 2003 | 07:19 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
the alston sfc's maybe? i dont know how much your e.t. will improve but it should with the lca upgrades, better traction
Old Oct 29, 2003 | 07:26 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
i think thats the brand alston.hey what this im reading its hard to put the sfc and removing carpet?
Old Oct 29, 2003 | 07:28 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
when you weld on the SFCs under the car, the floorpan can get hot enough to ignite the carpet.
alot of people pull back the carpet..... others just wet it down really good.
Old Oct 29, 2003 | 07:40 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
Old Oct 29, 2003 | 07:41 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
http://exit3.i-55.com/~davidlt/z28.htm
ignore this its a mistake
Old Oct 29, 2003 | 07:48 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
okay now i understand what about suspension loaded?
Old Oct 29, 2003 | 04:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Having the suspension loaded means that the weight of the car is on the tires. Or, it means that the car was lifted in such a way that the weight is on the suspension- an example of which would be raising the back with jackstands under the axle, and raising the front with jackstands under the lower control arms. This can be a dangerous way to lift a car... keep all safety procedures in mind.
Inducing a "preload" into a suspension is bad- that means you tightened down bushing bolts when the car's wheels were free-hanging (car lifted in the air by the frame). So when you put the car back on the ground, since you tightened the bolts with the suspension hanging, the suspension keeps it's "shape"- wheels hanging down. That results in a car being (A) higher then it was before you did the work and (B) with poor handling. A preload is induced into the bushings, which means the bushings are twisting up- they're trying to return to the same "shape" as when the wheels were hanging down.
Hope that helps!
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
