Alignment after wreck
Old Oct 30, 2003 | 11:13 PM
jac6695's Avatar
Car: Chevy Blazer
I picked up an 1994 Z28 that has been rolled. The car is not too bad and I need to get it road worthy to drive it from MD to CO. One main problem is the front tire are toed out. I was able to adjust tie rods to get toe close enough to drive to alignment shop. My question is, what could have made the alignment so bad. I can't find anything bent or otherwise damaged. I wonder if the something went wrong in the rack. Has anyone heard of a problem like this? Any long term effects? Thanks for any help.
Old Oct 31, 2003 | 08:18 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
There's definately something wrong with the rack.
Old Oct 31, 2003 | 10:14 PM
jac6695's Avatar
Car: Chevy Blazer
Do you know of any way to fix it (other than replace rack)?
Old Oct 31, 2003 | 10:55 PM
z28cdoyle's Avatar
Car: 85 IROC
Engine: 355
Transmission: Tremec 5 speed
I slapped a tire wall at a race track earlier this summer in my car. The RF tire was toed out badly afterwards and I also could not find anything broken or bent. I used the tie rods to aloign the tires but the steering wheel was off center. I pulled the steering wheel off, turned it a spline and reinstalled it.
Over the winter I plan to replace the steering box. I have seen posts from some other guys with the same problem after a wreck. To me, if you cannot find bent parts, the steering box has to be the part that is damaged.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
meeklay812
Oct 1, 2015 03:46 PM
tattmann
Sep 27, 2015 05:20 PM
