Need help with tire valves!!!
I have 16x8 IROC wheels on my car. They have steel thread in air valves that need replacement but i cannot seem to find them anywhere. GM doesn't list them either. does anybody have a part number for these??
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you talking about the needle valves in the valve stem? If so, you can find them in parts stores, tire replacement centers, Wal-Marts, and K-Marts.
The Trickster!!!!!!!!!!!!!!
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Every tire store I have ever been in sells them. The Iroc rims can not run a full metal valve stem (will not fit in hole insert) So we have to run at best a rubber stem with a metal sleeve over the exposed stem section. Again, any tire store.
Car: '87 Chev
Engine: 60*V6
Originally posted by laiky
your saying that the stem with a hex on it is just a cover?? I thought it was one piece. I'll have to go look again. If that is the case then i guess i just need the rubber stems.
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
