drum rear to disc rear
Old Nov 12, 2003 | 05:22 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Alright my friend is looking to get a bigger rear end so he will probably sell me his old rear with 3.73 gears cheap. I really want this rear end , but it is setup for disc brakes, and I have drums on my rear . What all would I have to do to make the disc's work? I'd appreciate any help I can get. thanks
Old Nov 12, 2003 | 05:25 PM
87Formula4bbl's Avatar
Car: '87 Formula
Nothing, its a direct swap. Although you are getting the old style disc brakes, which arent the best. You may need to get a 4 wheel disc brake proportioning valve though for more stopping power, the drum setups didnt put a whole lot of pressure to the rear I dont think.
Old Nov 12, 2003 | 05:32 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Oh so its a straight swap? I will probably just put it in and upgrade a little later. Thanks for the reply
Old Nov 13, 2003 | 10:10 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
actually its the other way around....drum brakes require more pressure than discs do....but ya you need to change the prop valve
Old Nov 15, 2003 | 09:01 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Not according to the SSBC web page.
Old Nov 16, 2003 | 01:50 AM
Car: '91 Camaro RS
dont believe everything you read on the internet.....go from a drum rear to a disc rear and crank up the pressure.....it will lock the rear brakes up
Old Nov 16, 2003 | 03:58 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
If I was to crank the press. on anything the brakes would lock up, disc or drum.
Old Nov 16, 2003 | 04:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its not really what the pressure is thats the issue... its the ratio.
you dont want your backs to lock before the fronts..... but you want the backs to be as close as they can be before the fronts lock...
Old Nov 16, 2003 | 11:07 PM
Car: '91 Camaro RS
well put
the fluid pressure inside the slave cylinder in a drum brake is usually higher than the pressure required for a disc brake on the same wheel
Old Nov 18, 2003 | 06:32 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
This swap was performed on my car, now I cannot hook up the E-Brake... live around hills.. its kinda important, any ideas?
Old Nov 18, 2003 | 07:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
can someone PLEASE be specific about this problem?
3rdgens ebrake work by pulling a cable.
4thgens ebrake work by pulling a cable
whats so hard about figuring out some way to pull the cable? whats the hold up i hear about so much that noone is specific about!?
the only "fix" i see is someone posted a super simple bracket.... is that it? are you guys driving around without ebrakes because of a silly little bracket?!?
Old Nov 19, 2003 | 12:32 AM
Car: '87 Formula
Yes, but it makes it a lot more practical when you have an auto. Not really any point in spending time in fabbing something up.
Old Nov 19, 2003 | 02:23 AM
Daishi's Avatar
Too tell ya the truth I havn't even looked at the damn thing yet, I'm too involved in other things.. sigh.. If that Power Steering pump would only hurry its **** on over here... *pout*
Anyway back to the E-Brake.... Guess I never really got a look at her, perhaps on a slower day Ill go have a look at her
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
