Is there any High / Low adjustable strut/shock
Old Nov 18, 2003 | 11:51 PM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
Hi,
I am thinking lowering my car, I thought it should be better to use both lowering spring and strut/shock, any suggestion??, I have heard about the "lower control arm" should be used after lowering the car, is it necessary ?
Old Nov 19, 2003 | 12:01 AM
CrazyHawaiian's Avatar
Car: too many ...
You will find more information in the Suspension/Brakes/Chassis forums. If you want to lower your car then a set of drop springs is a good choice. What spring you choose will depend on how you want the car to ride. If you want an adjustable shock/strut look for Tokiko Illuminas or Koni Adjustables, both are very good. Your car already has lower control arms (they are factory), but when you lower the car the angle of the lower control arms, or LCA's will change. To correct this you will want a set of lower control arm re-location brackets. Good luck!
customblackbird
Aug 15, 2021 10:16 PM
hemicudakidd
Aug 31, 2015 06:23 AM
Fronzizzle
Aug 19, 2015 01:36 PM
dcbsracing007
Aug 18, 2015 07:24 AM
