ENERGY-SUSPENSION endlinks for front swaybar
Old Nov 23, 2003 | 11:34 PM
joshwilson3's Avatar
Old Nov 24, 2003 | 02:37 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
i'm pretty sure you don't need to grease the endlinks. I never did when i put new ones on but i guess i could be wrong.
Old Nov 24, 2003 | 02:40 AM
Old Nov 24, 2003 | 03:02 AM
nikh23's Avatar
i used an airgun just made it tight enough so that they weren't lose at all yet still hadn't stipped the bolt. I do think that they included a sheet which had a recommended torque for the links
heh it really doesn't seem like i'm being much of a help here but to be honest i really don't think it would matter with the endlinks as to how tight they are
Old Nov 24, 2003 | 03:17 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
It does matter how tight you set your endlinks as yer setting preload which does affect handling. The number 85ft/lbs kinda sits in my head for some reason with endlinks...
Old Nov 24, 2003 | 11:16 AM
Old Nov 24, 2003 | 11:31 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
No need to grease endlinks as they arn't in a position to bind. I do wonder if it might extend the life of them tho....
Old Nov 24, 2003 | 11:34 AM
Old Nov 24, 2003 | 12:19 PM
MdFormula350's Avatar
15 to 16 foot pounds for the rear ones, the front ones are most likely the same.
Old Nov 24, 2003 | 12:49 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
guess the 85ft/lbs number in my head is for somethign else then haha
Old Nov 24, 2003 | 01:33 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: ENERGY-SUSPENSION endlinks for front swaybar
Originally posted by joshwilson3
I have got a new TDS wonderbra...
?! Hey, I haven't released THAT product yet.
... Do I need to use grease on the es end links for my front sway bar? [/QUOTE]
Not necessary, but it wouldn't hurt it if you did grease the urethathane bushings.
Also, how tight do I need to tighten the endlinks? I guess the suspension needs to be loaded so this would have to be done on drive on ramps, correct? [/QUOTE]
Tighten the end links to 16 ft-lbs.
Lon
Old Nov 24, 2003 | 01:57 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
