Suspension clunk - steering box torn loose?
Old Nov 28, 2003 | 11:05 AM
giff's Avatar
Car: 91 G92 Formula, 35k original miles and owner
Transmission: 5 speed
I've had a clunk from the front end that occurs just as your stopping that I've been trying to figure out. It's NOT the typical brake pad clunk in the calipers - this noise is different. Sounds more solid.
With all the posts I read about 3 gen's having a problem with the steering box breaking loose from the frame rail, I'm beginning to wonder if mine has cracked and what I'm hearing is the steering box & frame flexing and popping?
I only hear it just before I come to a complete stop and it occurs most but not all of the time. Never heard (or at least noticed it!) while turning either.
Giff
91 Formula, 305 TPI, 5 speed, 35k garage kept miles
Old Nov 28, 2003 | 01:29 PM
MdFormula350's Avatar
i dont think it would be the steering box because that usually occurs during low speed turning situations i think.
sounds more like maybe the sway endlinks, a ball joint maybe, or maybe a strut tower mount being wore down.
just some guesses.
Old Nov 28, 2003 | 04:24 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I dont think it would be steering either.
Sounds to me like torque arm bushing, or some bushing somewhere gone out.
Old Nov 28, 2003 | 08:03 PM
giff's Avatar
In trying to fix this issue I'll probably start with the end links on the sway bars and sway bar bushings.
Looks like I can get end links w/poly bushings for both front and rear sway bars for around $50 total. Besides maybe fixing this annoying clunk - anyone got any feed back on this mod? Noticable diff?
Just put on a steering brace off an Iroc and can feel slight diff in steering response.
Giff
Old Dec 1, 2003 | 12:39 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
I'm hearing a clunk in my steering too. It usually occurs when I'm turning the wheel as I back out of my driveway or when I'm turning into a parking spot. I've been under the car several times and I don't see any cracks. My car is pretty clean for a daily driver. You guys have any ideas? Maybe we've got the same problem.
Old Dec 4, 2003 | 01:32 AM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
I've had some creaks and clunks since I bebuilt the front-end of my car a year ago, mostly while turning at low speed and going over speed bumps. The KYB shocks I used didn't have the same locator on the upper mounting nut as the original and that could be a source. I think I overtightened the lower control arm bushings since the factory uses all-metal locknuts that read proper torque ONCE, not to be torqued to 70lbs a second time. I am going to address this by Christmas and will post results.
Old Dec 4, 2003 | 10:56 AM
DriftaGMCamaro's Avatar
Car: 1989 Camaro RS
Engine: L03 TBI V8
Transmission: M5
YEAH man
Im having the same problem when my car its just sitting there and as I turn the wheel to the right.. the noise sounds solid and harsh. My steering is horrible too. I mean if I turn the wheel a lil bit the car still goes straight, is it best just to take it all out and rebiuld it? and replace all bushings and inspect the struts and arms?
Old Dec 4, 2003 | 07:12 PM
Engine: 5.7L TPI
The only things I haven't replaced are the control arm bushings and the upper strut mounts. I also think I need to try adjusting the steering box.
Old Dec 4, 2003 | 08:00 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I've had a clunk when changing from forwards to revers and back. Having a manual tranny I only noticed it when I hit the brakes just after changing directions. For me it turned out to be a combination of the O-rings that go around the brake caliper pins and loose tabs on the outer brake pad.
Old Dec 6, 2003 | 08:22 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
check the inner and outter tie rod ends. my outter tie rods are shot and making a popping noise when turning at low speed sometimes.
Old Dec 8, 2003 | 12:43 AM
Car: 1989 Camaro RS
Engine: L03 TBI V8
Transmission: M5
YEAH
THANKS G money
Old Dec 23, 2003 | 09:44 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Ok, what else have we got out there for suggestions?
My exact problem.
I had a PST Polygraphite kit sitting around for about 6 months, finally got it in. I had this noise before and I still have it.
No cracks near the steering box.
So, basically, what I've done that hasn't resolved the problem, just to address some of the suggestions presented:
* Control arm bushings
* Ball joints
* Tie rod ends (outer from PST, inner and sleevs from AutoZone, brand: "Perfect Circle")
* Disc brakes & hardware replaced (pins, clips, pads; calipers still what came on the car)
* Sway bar endlinks
Old Dec 24, 2003 | 01:41 PM
Engine: 5.7L TPI
My next step was to replace the strut mounts and that didn't solve my problem. So far I've replaced the tie rods, strut mounts, and ball joints. I don't want to waste money on a new relay rod or pitman arm if I don't need them, but I'm not sure what else to do. I haven't had the steering box checked, but I'm cautious about doing that too because I imagine it will be expensive or time consuming if I do it myself.
Old Feb 10, 2004 | 11:39 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
hmmm... anyone figure this out yet? I sitll have the problem and there's nothing left for replace.
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
BlackBoulder
Aug 11, 2015 11:15 PM
