Show me your sub frame connectors
Old Nov 30, 2003 | 02:01 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
I am looking into getting some sub frame connectors, and would like to see some pics of various different types mounted on cars. Are all weld on type, or is there a bolt on type. Any information you can give me would be appreciated. Thanks alot Jason
Old Nov 30, 2003 | 02:29 PM
Irocster's Avatar
Car: 1989 IROC-Z
Transmission: 700R-4
Spohn Tubular....weld in....
You can find both weld in and bolt in. Everyone here will tell you to get weld in, for a very good reason because they are much stronger. It took a muffler shop a good 1.5 hours to install with one guy up in the car the entire time with a spray bottle and the carpet pulled back. Well worth the money IMO.
Old Nov 30, 2003 | 02:30 PM
Irocster's Avatar
Car: 1989 IROC-Z
and....
Old Nov 30, 2003 | 05:44 PM
88txiroc's Avatar
Nah...........go with the Alstons. Much better of a subframe connector. These really DO connect the front and rear subframes together. Do a search for "Alston's" and you will find many threads where the debate goes on................
Old Nov 30, 2003 | 06:04 PM
PhilM's Avatar
Car: Accepting applications...
one debate that will never die. I love Spohn equipment, but I think the Alstons are the way to go.
Old Nov 30, 2003 | 06:23 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Moving to Suspension/Chassis
Old Nov 30, 2003 | 11:07 PM
Irocster's Avatar
Car: 1989 IROC-Z
I still say spohn. They improved the car a lot. Just from looking at my pics and the alstons, the spohn looks to be a much better design IMO. My muffler guy (who also does a lot of fabrication work) said they are the beefiest and best design he's ever seen. I'm very happy I went with them.
Old Nov 30, 2003 | 11:32 PM
joshwilson3's Avatar
Old Nov 30, 2003 | 11:50 PM
MdFormula350's Avatar
yes you should be able to run both fine. i wanted the alston's also but i think my tranny crossmember might get in the way. need to do some researching on that.
might need to notch either one i think.
Old Dec 1, 2003 | 01:40 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Both are a good SFC. I hear that Kenny Brown SFCs are also a great design.
Generally, I have read on this board that the Spohns are better for weight transfer and the Alstons are better for handling. Both firm up the chassis.
I haven't heard much about Kenny Browns except that they have SFC's and Super SFC's... like stage one and stage two the Super SFC's are used as an upgrade WITH the base SFCs.
Old Dec 1, 2003 | 03:24 AM
25THRSS's Avatar
go with the spohn design.
Lanz06
Sep 14, 2015 07:16 PM
Amillionoh7
Sep 11, 2015 11:36 AM
scotrans am
Sep 5, 2015 04:26 AM
middian
Sep 5, 2015 01:42 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
