minor gearbox adjustment needed?
Old Dec 1, 2003 | 02:25 AM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
I have a little bit of play in my steering, that seems to be an equal ammont in both directions.
first I'll go ahead and let you all know every thing from the gearbox down(including the gearbox) is only a few months old.
I finaly got sick of the play and had a friend of mine turn the steering wheel back and forth with the ignition in the on position but the car not running.
the steering shaft moves perfectly with the steering wheel, and the little grear that it connects to on the gear box immedalty moves with it, but the gear the pitman arm connects to doesnt move at all.
the gearbox is a remanufactured one so Im wondering if this may be the reason for this problem. misadjustment due to a hurried reman possably? I read some where that its common for remaned boxes to be adjusted wrong.
I was thinking about adjusting it with some one moving the steering wheel back and forth to let me know when the play goes away, but wanted your alls oppinions first.
Old Dec 1, 2003 | 01:33 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Your sure its not the steering coupler, lash in the linkage, air in the ps system, or box loose on the frame? If everything there checks ok then go here
Infested
May 22, 2018 11:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
