Dead Spot in Steering
Old Nov 21, 2003 | 07:54 PM
stiers's Avatar
Not sure if this is where it belongs but it seems to fit here best so here we go. I seem to have a dead spot in my steering on my '92 RS. About 2 inches or so of steering wheel movement has no feeling in it. When I hold the wheel in the center it feels dead like it isnt connected to anything. I watched the wheels while I was moving the wheel in hte dead zone and it is moving them, but I can't feel the movement. Is this normal for these cars? Is there any way to fix it?
Old Nov 21, 2003 | 10:55 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
I'd be curious to know what other people's experince with this is also. My car seems to have the same sort of feeling to it, although I'm hoping it will change some when I install my new steering brace from TDS next week So does anyone else's car feel like this?
-Paul
Old Nov 22, 2003 | 12:57 PM
ebmiller88's Avatar
I've got a bit of that in my Iroc now. There's a procedure to adjust your steering box, tighten it up a bit. I just can't remember where it is right now.
If I find it, I'll post it.
Ed
Old Nov 22, 2003 | 08:17 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Adjustment for the steering box requires the steering box to be removed. If not, overadjustment could be caused. I've had people try and tell me that they adjusted theirs in the car but later I find out they had a near death experience doing so. If the pinion gear is overtightened the box WILL lock up and its very scary when the steering wheel won't turn. GM's service calls for the box to be on a bench. I'll print it out tomorrow at work.
Old Nov 22, 2003 | 11:47 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
No4NJunk is very right in that bad things can result from overtightening. That being said, mine was adjusted while on the car, but untortunately, I missed how it was done. I asked him how its done and thought I understood, but when I looked at it I realized I didn't...
Old Nov 23, 2003 | 04:43 PM
No4NJunk's Avatar
I printed the article. but first I'll explain how to do it in the car first.
I claim no responsibility for what happens.
With that out of the way you'll need some allen wrenches and some metric wrenches (forgot size and too lazy to go look). basically you'll look down on the steering box and see an adjusting nut on the top. It has a pitman shaft endplay
adjuster through the middle of the nut. put the allen wrench in and hold it while loosening the nut. Then tighten (very little) the allen. Then, holding the allen still, tighten the nut. fire the car up and turn the wheel to replenish any displaced fluid. Then test drive. Repeat until you achieve desired results. DO NOT OVERTIGHTEN. If you feel the steering bind at low speeds (before you get out of the parking lot) then do not go on the open road. Loosen up and retry.
Now for the On bench method.(this is exact copy)
1) Rotate stub shaft from stop to stop, counting the number of turns, then turn back exactly 1/2 number of turns to locate center of travel.
2) Measure combined ball and thrust bearing preload using an inch pound torque wrench to rotate stub shaft through the over center position.
3) Tighten the adjusting screw while rotating the stub shaft with torque wrench until torque reading obtained is specified inch pounds greater than combined ball and thrust bearing preload (6"-10" pounds). Note that total steering gear preload must not exceed specs (18" pounds).
Old Nov 23, 2003 | 04:56 PM
quadgoat's Avatar
Car: 1992 Firebird
Great info guys. Thanks for all the help!
-Paul
Old Nov 24, 2003 | 04:34 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
I had noticed a lil' dead space in my wheel too - I always wondered how to fix that...
Old Nov 25, 2003 | 01:12 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I always thought the box was just worn out, nice to know I can asjust it now, as soon as I find my 15mm wrench
Any guess on how much a 'little bit' of an adjustment is? I'm gonna try 1/4 turns on the allen and see how it responds. Is there anyone who has adjusted it and remembers how much they have had to turn it?
Old Nov 25, 2003 | 01:19 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
15mm? Good night.
Old Nov 25, 2003 | 03:55 PM
Thirtybird's Avatar
go slow, 1/8 turn, then drive it, if its still bad, repeat. It's easy to overdo. May seem like a hassle, but you don't want to take a shortcut here.
Old Nov 27, 2003 | 08:51 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Did I say 15mm cause I meant 16mm. I just did this adjustment today, it made a big difference in the feel of the steering, mine was way way off, I must have put a full turn in the thing. I think I could go a little bit tighter but I hesitate because I definetely don't want to adjust it too far.
Old Dec 1, 2003 | 01:51 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
From the Chiltons manual that I have.
*warning these are huge pic's*
http://www.nethirdgen.org/kat/steeri...20page%201.jpg
http://www.nethirdgen.org/kat/steeri...20page%202.jpg
http://www.nethirdgen.org/kat/steeri...20page%203.jpg
http://www.nethirdgen.org/kat/steeri...20page%204.jpg
http://www.nethirdgen.org/kat/steeri...20page%205.jpg
http://www.nethirdgen.org/kat/steeri...20page%206.jpg
Kat
db057
Apr 28, 2019 07:45 AM
Veaceonee
Sep 29, 2016 08:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
punkmaster98
Sep 8, 2015 09:45 PM
