Re: 9-bolt 1le swap
Old Dec 10, 2003 | 05:32 PM
Rob116's Avatar
Car: 1986 Z-28 Camaro
Engine: 355
Re: 9-bolt 1le swap
Hello,
Currently, I've got a 10-bolt drum brake setup on my car. I've been offered a full posi 9-bolt setup with 1le discs for $350 Canadian. What's involved in making the conversion? I'm planning on picking up a set of used 3.42's off of 9bolt.com, but what's involved in the brake conversion? I've been told by some that the only thing I'll have to change is e-brake cables, but other people have said proportioning valve, etc. will have to go, too. Help please!
Old Dec 11, 2003 | 04:16 PM
Parrydise7's Avatar
Do a search. This subject has been covered extensively. All the info you need is available.
Old Dec 12, 2003 | 03:48 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Yeah, search a little...I've covered it 100 times in my posts....BUT, to help a member, here's #101:
This is for your '86, stock disc/drum, right?
OK. You'll need the correct e-brake cables for those brakes,('90-92 disc/perf pkg), and a xxxx9496 prop valve. You will be OK with your J50 (disc/drum) master as those were used on all cars '89-up, regardless of what brakes they had on them. I also listed the "1LE" prop valve. You should be OK with installing this one and that's what the rear PBRs use. Other than that, you're all set...the rear is a bolt on. You mentioned 3.42s...you sure you don't want 3.45s for the 9 bolt?
Just checking...Ed
PS: Check my posts as I've listed all the props and master cyl part numbers on the boards before.
Old Dec 14, 2003 | 08:31 PM
Rob116's Avatar
Engine: 355
Thanks very much, and apologies to all. I DID do a search, but was looking in all of the wrong places. I think that I was looking a bit too narrowly and missed all of the most basic and extensive 1le posts. My fault, sorry. I did find them, not 10 minutes after Parrydise's intial response.
I'm not very knowledgeable when it comes to nine-bolts, as you can see, so I appreciate even your minor correction, ed(?).
Much obliged too all of the folks at TGO,
Rob
Old Dec 14, 2003 | 10:49 PM
ebmiller88's Avatar
No problem, man. I just don't like to type all those numbers all over again.
I'll be working on a 9 bolt-style PBR swap in the future and will post the results.
Ed
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
