Break question Help Please
Old Dec 16, 2003 | 07:44 PM
mrtransams's Avatar
Car: 91 firebird - 81 TA
Engine: 305- 400
Transmission: 5 speed
I have a 91 firebird on the front the pass side break locked up it would seems the break is not releasing so I replaced the breaks calipers and rotors and it still seems the break is not releasing what is the problem I just took it around the block and it got so hot it was smoking
Old Dec 17, 2003 | 01:10 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
More than likely your BRAKE hose. You should have replaced those also as they wear out and clog up over time, causing the caliper to hold pressure. Replace both and you should be OK.
Ed
ktthecarguy
Jul 5, 2020 11:46 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
89fast5oh
Aug 24, 2015 08:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
