Strut Tower Brace (ede?)
Old Dec 20, 2003 | 01:51 AM
Mathius's Avatar
Ok, I did a search and I've seen some stuff on buying stb's, and on making your own sfc's, but I didn't find anything on making your own stb. I have a few questions, even though it seems mostly straight forward....
What's the best way to mount them? It seems to me that bolting them into the engine bay sheet metal doesn't seem like a strong way to mount them. I had thought of making them mount somehow on the strut towers themselves, but I don't even want to consider what kind of mess that would make when getting an alignment. What kind of effect would it have if I mounted them to the doghouse rails?
What wall thickness do you guys recommend? .187? and if I use a pipe bender to form the angle where they angle down to the mounts, will that weaken them considerably? I see that hotchkis uses bolts to hold them in place, I considered that, but it seems to me that a one piece design is stronger. The alternative is to have two pieces where the angle is, and weld them together instead of bending the angle, but pipe welding is the most difficult type of welding to get 100 percent penetration, and I'm still a student.
If anyone can add any other tips or viewpoints here, I'm all ears.
Mathius
Old Dec 24, 2003 | 06:13 AM
ede's Avatar
ede
i'd look at catalogs or pics of cars with STB installed and decide what you like, or even mix and match ideas and features. making one wouldn't be hard to do, either miter and weld for the direction change or bend. a larger conduit bender works well for makign bends, used one for years making chassis for karts.
Old Dec 24, 2003 | 07:37 AM
85TransAm406's Avatar
Car: 1985 Trans Am
Try these...
https://www.thirdgen.org/techbb2/sho...hreadid=116737
https://www.thirdgen.org/techbb2/sho...hreadid=212276
well, if i can get them to work....
Old Dec 24, 2003 | 01:11 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: Strut Tower Brace (ede?)
Well consider this, the sheet metal where the struts mount is strong enough to take the pounding of the struts and keeping the entire top of the suspenion in position for a couple of hundred thousand miles of this abuse, so it's not as weak as you might think.
You could make some plates to sandwich a strut bar mount under the strut tower mounts, and with owning a machine shop I at one time considered doing this. But if you have power brakes, the strut bar will interfere with the M/C.
I also considered putting some kind of mounting tab on the billet strut mount I make for a strut tower brace, but the problems with aligment and material strength considerations of 6061 aluminum, I chose not to do this.
But as ede said, look at the catalogs and experiment. As I recall Jerrywho came up with an innovative 10 point STB. Do a search for that post and it may give you some ideas on how to make one. I've got to say it was one of the most innovative ideas I've seen on here in a long time. Great job Jerry If Jerry sold those, I'd buy one.
Hey Jerry, want to trade some billet strut mounts for a 10 point STB?????
EDIT: Here is a link to Jerry's post about his 10- point STB.
https://www.thirdgen.org/techbb2/sho...light=jerrywho
Old Dec 24, 2003 | 01:28 PM
Car: 1985 Trans Am
yeah, that's the link i tried to post, along with one ona 2-point made with rectangular steel with only a mild arch to clear the intake. I'll get the posting link thing figured out one day...
Old Dec 24, 2003 | 03:18 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The hotchkis sig. series STB is nice!
Here's mine:
Old Dec 24, 2003 | 11:35 PM
JERRYWHO's Avatar
Re: Re: Strut Tower Brace (ede?)
I think we can work something out.
A few questions about your car
What year.
A/C or A/C delete.
alternator STD or 1LE.
Hood stock or aftermarket.
Air filter system stock or aftermarket.
Factory overflow tank.
Factory windshield washer tank.
Jerry
Old Dec 24, 2003 | 11:44 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I'll have the rest of mine finished about the 5th of January. It will be for the HSR and be routed as shown by my crappy paintshop picture. I copied some Hotchkis brackets but made them out of aluminum and polished them. There is plenty of clearance with this routing, and it will be "4 point". The bar will be made from 1" 4130 chromemoly and I will use gussets at the bends to increase the rigidity of the piece.
Old Dec 25, 2003 | 08:20 AM
Mathius's Avatar
Jerry, can you give me shots of how you mounted the plates? Did you weld threaded rods to the bottom and just bolt it on?
How did you make the bends? Obviously a pipe bender can be used for this, but you said you used your car as a jig, did you weld the stb while bolted to the car?
Mathius
Old Dec 25, 2003 | 12:07 PM
JERRYWHO's Avatar
Mathius
I don't have any pictures right now. I will take some and post them later today or tomorrow. All the plates are formed on a 100 ton Cincinnati CNC press brake. The tubing is bent on a mandrill tubing bender that I use to produce sprint car chassis with. All the tig welding was done with the stb clamped in the car.
Jerry
Old Dec 28, 2003 | 05:40 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Hey Jerod I will throw down some $$ if you could make two of those since you have pretty much helped me on going for the stealth ram!
Old Dec 28, 2003 | 08:13 AM
JMatlock88's Avatar
Car: 1991 Formula
We'll see...one-off parts are always pretty time consuming and my time is limited right now. It would have to be very much worth my while.
Old Jan 4, 2004 | 01:15 AM
Mathius's Avatar
Were you able to get those pictures, Jerry?
Mathius
Old Jan 14, 2004 | 01:17 AM
Mathius's Avatar
I hate to nag, but that thing is too sweet not to try and get more details.
Bump.
Mathius
Ed1LE
Sep 30, 2018 09:14 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
