Do spacers affect performance?
Old Dec 20, 2003 | 01:31 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
I really like the look of the Z06 wheels, and plan on getting them for my camaro eventually. I also want my car to handle as good as possible. I'm getting all Spohn suspension parts, eventually a rollcage and LS1. My question is, will having the spacers up front affect how the car will perform. I will be gettign a different rear end so i won't need the spacers in the back. Thanks
Old Dec 20, 2003 | 06:41 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I was running 2.25" spacers all around and didn't notice any ill effects. Car handled great with the new 17" wheels and 275/40 rubber.
Old Dec 21, 2003 | 02:07 PM
BOTTLEDZ28's Avatar
Transmission: A4
the spacers wont effect your performance but they do put a lot more stress on your wheel bearings. the spacers postion the wheels furhter outward of the wheelwell. This is what I have heard. If it is indeed true then the wheel bearings will not live as long.
Old Dec 21, 2003 | 03:44 PM
Zepher's Avatar
So, would wheels like the ROH Snypers that are made for the thirdgens cause more stress on the wheel bearings as well?
Old Dec 21, 2003 | 03:58 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
its not the wheel spacers themselvers that put more stress on the bearings,
by making the wheels wider, there is more wheel outboard of the centerline of the hub.....this is what puts more stress on the beairngs.
using spacer is just artificially duplicating the backspacing that would be required to install the wheel.
like for example, if you welded the wheel spacer to the wheel....it would be the same thing as a wheel made that width with the required backspacing.
so its the overall width of the wheel, especially outboard of the center of the hub, that would put more strain on the bearings...
but in general its not a huge problem to worry about
Old Dec 21, 2003 | 05:13 PM
Kandied91z's Avatar
if you plan to use spacers no, if you are going to use adapters which will be the likely case then yes and no.
i personally didn't like them but that's me. are you going 18 or 17's all around? i have a custom set of adapters to fit the 18's up front for sale if your looking.
good luck.
6speedIROC
16
Mar 15, 2023 08:33 PM
Elephantismo
Feb 13, 2019 12:51 AM
skinny z
Oct 5, 2015 06:23 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
