subframe connector problems?
Old Jan 7, 2004 | 07:01 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
how difficult are the subframe connectors to install? i know they come in two forms. weld in and bolt in. which is an easier install? which is better?
Old Jan 7, 2004 | 07:38 PM
MdFormula350's Avatar
even with bolt in ones you still want to weld them in.
i say weld in's are the easiest, a hour at a good muffler shop should be able to install them for around 100 bucks.
i use the spohn ones, but other brands are alston's, comp engineering, etc....
Old Jan 8, 2004 | 05:04 AM
ede's Avatar
ede
i'd rate SFCs as about as easy as anything you'd ever do. that is as long as you have a welder and few basic tools.
Old Jan 8, 2004 | 05:14 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
personally i like the jegsters,they have been out longer than most and whom ever made them obviously owned a thirdgen and got them right,easy bolt in and i have them welded,easy!!
Old Jan 8, 2004 | 10:05 PM
Engine: 355
thanks guys. i appreciate the info. i have a welder, so i will try it for myself. thanks again.
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
