CV Joints?
Old Jan 8, 2004 | 07:31 PM
brad92's Avatar
Car: 92 rs camaro
Engine: 3.1L v6
Transmission: auto with overdrive
CV Joints?
My family has a 87 2.8L camaro. the suspension in the rear end is getting really back. it shakes, ratlles, and makes alot of noise. we were told it's the CV joint, yet we have no clue what they are, what they do, and how hard they are to replace? anyone know, please help. thanx
Old Jan 8, 2004 | 07:44 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
no CV joints on our cars.
Old Jan 8, 2004 | 07:46 PM
brad92's Avatar
Car: 92 rs camaro
Engine: 3.1L v6
what are they?
Old Jan 8, 2004 | 09:04 PM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
Axle/Gears: Slow lol.
Maybe you or they are meaning the U-joint? CV joints are mostly on front wheel drive cars. Works like a U-joint, but is part of a FWD drive axle. Now if the car was an RX-7 or Vette, then yeah, I could understand a CV type joint being a problem, lol.
Old Jan 9, 2004 | 11:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No CV joints on those either.
Old Jan 9, 2004 | 12:24 PM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
You sure?
FC RX7, under the typing:
Newer Vette:
Now, correct me if I'm wrong, but those look like IRS with CV style joints on the rear axles coming from the differential. The older Vette's, and other older cars with IRS, had reg. U-joint axles coming from the differential.
Datsun 510 with 65-79 Vette rear differential and IRS:
I dunno, maybe I'm seeing things lol.
Old Jan 9, 2004 | 01:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ah, true enough, I wasn't thinking of the new stuff.
Old Jan 9, 2004 | 01:56 PM
ede's Avatar
ede
brad most likely they meant the u joints. the part that connects the drive shaft to the rear end and to the transmission yoke. i see you live in boyertown. i work for cabot but at the columbus location.
Old Jan 10, 2004 | 07:06 PM
brad92's Avatar
Car: 92 rs camaro
Engine: 3.1L v6
i think the personm is talking about U joints. i did some searching for cv joints on camaros before and i didnt find anything but now i did some searching on just cv joints and you're right there arent any on our cars, but i did notice the u joints, thanx alot.
Old Jan 11, 2004 | 07:10 AM
ede's Avatar
ede
didn't some late 70s early 80s caddys use CV joints on the drive shaft? seems like i worked on one that had to be replaced, but i wasn't the one that did the replacing.
Old Jan 11, 2004 | 10:28 AM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
The Eldorado/Buick Riviera/Olds Toranado had them. But those were FWD, AFAIK.
Old Jan 11, 2004 | 03:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's no reason why you couldn't use one I guess, it's just another type of universal joint. I wonder if there'd be any performance benefit from not having to accelerate the cross.
Old Jan 11, 2004 | 04:52 PM
ede's Avatar
ede
no it was RWD and cost was around 200 dollars for the part. i wasn't working on it but i can damn near picture it on the rack in texico station i worked in in high school
Old Jan 11, 2004 | 05:23 PM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
It wasn't the Allante was it? But I think that was FWD and based on a shortened Eldorado chassis. That was one of the oddballs from 87-90 I think. I have yet to work on one, so I'm not sure how the drivetrain and chassis is designed.
And the Cimarron, based on a Cavalier/Sunbird J-body chassis, and that was FWD too. That's an outcast that didn't last too long. Other than that, it was the usuall Caddys.
Who knows, lol.
Old Jan 12, 2004 | 04:52 AM
ede's Avatar
ede
no this would of been about 75-77 time frame, i know i was still in high school. i might not remember what i think i do too
Old Jan 12, 2004 | 05:03 AM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
Yeah, it may have been something other than a Cadillac. Who knows, lol.
Old Jan 12, 2004 | 07:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
My 74 Caprice 454 convertible has a double Cardan joint at the rear of the drive shaft.... uses 2 U-joints and a ball thing in between them, and a ring-shaped yoke.... they used to call that a "constant velocity U-joint". A real PITA to change.
But these cars don't have that, just a single U-joint at each end. They're not too hard to replace.
Old Jan 12, 2004 | 08:08 AM
ede's Avatar
ede
i feel better now knowing i had heard of CV joints way back then
Old Jan 12, 2004 | 11:09 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
got that in my winter vehicle(86 bronco) snapped the damn thing in half one night and drove home in 4wd at like 10 mph. had to go about 12 miles so that really sucked. easiest way to replace it is to cut of the old and weld on the new! lol
Old Jan 12, 2004 | 02:04 PM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
OK, now I got what you were probably talking about. Those in that pic are what's on the BIG cars of the '70s. These days when comeone says CV joint, you automatically thinks it's the kind like on a FWD car. So, like a dummy, I forgot about those in the pic, lol. Oops!
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
bubbaz28
Sep 18, 2015 02:09 PM
