Z06 RIMS ON A 3RD GEN????
Old Jan 12, 2004 | 01:34 AM
daddy33's Avatar
Car: '85 Camaro
Hey guys i had a question, my uncle got a Z06 corvette a little while ago and put on some light weight racing rims on and has the chrome Z06 rims and tires sitting on the side! He said that i can have them but i wasnt sure if the bolt pattern on the Z06 would fit on my '85 camaro (im sure mine is 5x4.75) anyways these are BRAND NEW FREE! rims and tires he has aside. He lives 2 hours away from me so i dont have much time to go down and try them on. Anyways i wanted to know if those Z06 rims will fit on mine or if there is some kind of adapter. Please let me know a.s.a.p!! Thanks!
Old Jan 12, 2004 | 03:39 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
You need adaptors...just like any other Corvette rim or 4th gen rim...
www.skulte.com
The ones you want are the 2" adaptors...Price is about $300 for the set of 4.
Old Jan 12, 2004 | 03:46 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
i heard u will have problems runnig these rims if your car is lowered. Does anyone know if this is true because i was planning on picking up some zo6's also 17by9.5 thanx
Old Jan 14, 2004 | 12:25 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
TTT
Old Jan 14, 2004 | 01:51 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Wheels.
There might be a bit more response for this from the appearance and detailing board, where all the wheel junkies hang out. You will definately need spacers, as 88TPI said. Some wheels have higher offset than others and you will either need 2" spacers all around or maybe 2.25" in the front. Go to the link or call skulte and get the exact fitment for your application. As for lowering, the only time I've heard of lowering issues on the Z06's is when you're running 10.5" wheels in the rear, in which case you probably won't be able to go further than an 1" (Pro-Kit). I myself have 17X9.5" ZR1's and run a 2.25" adapter in the front and my rear is from a 4th gen so I don't need adapters. Everything fits well:
Old Jan 15, 2004 | 01:01 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
you can give them to me im going to buy some anyway. if you update to a 4th gen rearend you only need two adapters since the 4th gen rearend is roughly 2inches wider on each side. Man i love the Z06 wheels
Old Jan 16, 2004 | 04:17 AM
Pat Hall's Avatar
Dude get the adapters and go for it! Have you priced a set of the Z06 wheels new??? I wouldn't be able to buy the adapters fast enough if I had the chance to get the friggin wheels and tires for free!
Old Jan 16, 2004 | 09:24 AM
mongse_1's Avatar
Car: '95 TT Trans Am
Engine: 383 LT1
Transmission: TH400
http://www.quarter-mile.net/images/I...els_index.html
Don't remember if the car is lowered, but it definitely has Andris' adapters on it.
Old Jan 16, 2004 | 07:06 PM
Kandied91z's Avatar
plenty of people running this wheel, just do a search and you'll find all your needed info. i have a set of adapters that will fit the front specs perfect for 150. talk to andris as he will help you out the best he can.
Attached Thumbnails Z06 RIMS ON A 3RD GEN????-jeff-full-passenger-profile
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
