Need HELP please, with offset for 17 x 11 !!!
Car: Faster
Engine: Than
Transmission: You!
I will be putting a set of 17 x 11 ZR-1 wheels on the back of my car and I need help with offset.
I will also have a Moser 12 bolt from a 4thgen under the car.
So, with my 4thgen rear, what offset do I need to get my 17 x 11 ZR-1's in, so they dont rub or stick out too bad ??
I shouldn't need spacers in the rear since I have a 4thgen rear, right?
Car: 91 RS
Engine: 305 Tbi (L03)
I think youll be alright in the rear. To figure out what spacer you need just measure the backspacing of your curent wheels and the new ones and subtract.
Car: Faster
Engine: Than
Transmission: You!
Are you saying that I WILL need a spacer even with my 4thgen 12-bolt ?
I thought if you had a 4thgen rear, you dont have to run a spacer?
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Why don't you read :
http://www.skulte.com/adapterfaq.html
And measure what you've got, and calc what you need according to the method described in the above faq.
Si.
Si.
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
1bad,
Once you figure out what you are going to do about wheel fitment, post your results. I too am trying to figure out how to make the 17 x 11s fit a 4th Gen rear. I found a stock SS rear for really cheap and would like to throw that in my 92. I would need to get a matching pair of wheels though.
The specs on that website were useful for me as a possible starting point...
Car: Faster
Engine: Than
Transmission: You!
I dont have the wheels nor rear end yet.
Thats why I needed the info, cause there are a few offset choices to choose from when buying a 17x11 ZR-1 wheel.
I dont want to buy the wrong ones!
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I think it's the 36.5mm offset if I'm not mistaken with the 4thgen rear. I'm doublechecking that now as well...have a 4thgen rear under my car, but could really use a 12 bolt!
Correction: with a 4thgen rear and 36.5mm offset tires you'd stick out another 3/4 of an inch so you'd probably need more fender flare...according to the chart on www.skulte.com, with a 3rdgen rear a high offset (50mm) 17x11 wheel needs a 2" spacer...the exact spacing you get with a 4thgen rear. So you should be fine with 50mm offset wheels.
Car: Guess
Engine: Crazy 8
So, if you are running or are planning on running a 4th Gen rear and want to use 17 x 11s, get the ones with the 50mm backspacing to fit inside the fender. I really want to run the wider rear tyres if I put a 4th Gen rear in the car, but I DO NOT want the tyres to stick out too much. About a 1/2 inch is all I could stand. I am afraid it would look dumb if I lowered the car. I guess I could ask the body shop to add some flare to the rear fenders.
A body shop could do that right????? I don't even know how one would go about doing that kind of thing...
Thanks for the info though!!!
88SS6SPEED
Nov 11, 2015 07:05 AM
rb85TA
26
Sep 14, 2015 10:29 PM
