Standard offset
Old Jan 25, 2004 | 01:46 AM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
Standard offset
what is the widest tire i can fit on standard offset wheels on my 86 ta? they are 15 inch by 8 btw. Thanks in advance
Old Jan 26, 2004 | 06:36 AM
CrazyHawaiian's Avatar
Car: too many ...
Since they are 15's, you can get a tire with a big sidewall. This means the sidewall will flex and you can accomidate a wider tire. If I were you I would decide on what brand/type of tire you want, look it up on the companys website (spec sheet PDF) and find the widest tire that fits your wheel width. You'd be supprised what widths you can get away with. Your wheel is 8 inches wide .. I think 275/60/15 DR will fit, so will 275/50/15 DR, and so will (yes its true) 295/65/15 DR's. Just remember to always keep the load rating and tire pressure in mind. Also 8" wide rear wheel factory specs are +16mm offset and 4.5" backspacing.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Gunner242
Dec 25, 2015 04:49 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Bigold4x4
Sep 28, 2015 05:21 PM
