tie rod and ball joint...
Old 01-26-2004, 05:11 PM
MurCurY's Avatar
Car: 86 Camaro Berlinetta
I am getting this NASTY shaking around 45MPH....I'm thinking it's the ball joint. I've also heard it could be the tie rod end....so...I've decided to do them both at the same time. How hard are these to do? How long might it take? Is there a FAQ on it...makes it a ton easier. I'll be getting autozone parts....will these be ok for a stock car and how long will they last? Thanks.
Old 01-26-2004, 07:14 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Moving...
Old 01-26-2004, 09:01 PM
johnyIROC's Avatar
A bad ball joint makes a nasty creaking noise, but shouldn't cause too much shaking. My guess would be that the tie rod ends are out of adjustment or need replacing.
Old 01-26-2004, 09:29 PM
MurCurY's Avatar
it is creaking....LOUD...but only when i'm going slow. I'm going to jack it up and check it out thursday when i get off.....how hard is it to replace? You can adjust the tie rods? How would you do that?
Old 01-27-2004, 03:25 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Don't know if this applies to you but I've had creaking also before, but that was from the coil spring not seated correctly
Old 01-27-2004, 05:13 AM
ede
ede's Avatar
ball joints and tie rod ends casue shimmy more than vibrations. you migth want to do a little investigating before you go swapping parts. i wouldn't use front end parts from auto zone if they were free. look in your manual for instructions on the r&r.
Ed1LE
09-30-2018 09:14 AM
Bohemian
Aftermarket Product Review
11-25-2015 09:38 PM
LT1Formula
10-08-2015 08:34 PM
loud91rs
10-05-2015 10:05 PM
sjorgens
10-01-2015 07:54 PM
Quick Reply: tie rod and ball joint...
