How should car be sitting when SFCs are welded in?
Old Feb 8, 2004 | 09:08 PM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
would the car being lifted or on stands effect how the car will sit/ride when welded in? if the frame/body is bowed when lifted. wouldnt their be problems?
anyone have problems? or how was your car sitting when they were put in. i dont want mine welded in in the wrong angle/position because the car was hanginf crazy on one side ect.
Drew
Old Feb 8, 2004 | 09:13 PM
Irocster's Avatar
Car: 1989 IROC-Z
Transmission: 700R-4
The SFCs should be installed on a drive-on lift, where the weight is dispersed evenly on all four wheels.
Old Feb 8, 2004 | 09:45 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
What he said. I did mine with the front on ramps and the rear up on jackstands. ever jack your car up to change a tire? a front tire? while the wheel is off the ground look at the gap where the door meets the fender. at the top, near the hood the gap will spread over 1/2"- the bottom of the fender will be almost touching the door. make sure your car is flat and level before you weld !! when i was shoping for a garage to put mine on i had so many shops tell me " sure, bring it on in and we'll throw it on the lift"
Old Feb 8, 2004 | 09:52 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
how much would it cost for you to get it on a lift or get a shop to just do it for you?
Old Feb 8, 2004 | 10:46 PM
MdFormula350's Avatar
most shop charge around 110 for sfc's install, a good muffler shop will be able to do it.
Old Feb 8, 2004 | 10:55 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Well if you can weld it yourself, why not just put it up on 4 ramps?
Old Feb 9, 2004 | 12:34 AM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
I paid $70 to install my Alstons at my local muffler shop.
Ryan
Old Feb 9, 2004 | 02:38 AM
3rdGenBlackBird's Avatar
Is there anything that should be done before you weld in your sfc's? Like alignment, checking the frame's straightness, etc? Or just keep the suspension loaded and go?
Laters,
Scott
Old Feb 9, 2004 | 04:59 AM
ede's Avatar
ede
if you do it at home, or not on a drive on lift take some referance readings with an angle finder on a known level surface. support the car on jackstands and replicate the angle finder readings.
Old Feb 9, 2004 | 05:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I had mine done on a race car chassis jig.
Old Feb 9, 2004 | 07:18 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you just need the chassis loaded on the suspension..
so you could just drive it on ramps, then put a jack under the rear, and lift it... then put stands under the rear axle.
the suspension is loaded just like when its on the ground.
Old Feb 10, 2004 | 01:33 PM
If I put in sfc and then lower my car will it mess up the angle? Should I lower it first?
Old Feb 11, 2004 | 12:42 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well.....I had mine done on a "Super" race car chassis Jig!!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
kyleb24
Aug 15, 2015 08:24 AM
