fbody "x-brace" on ebay??
Old Feb 10, 2004 | 05:36 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Just curious if anyone ever new this existed for 1st gen verts. What happened to x-braces for the later generations? Can anyone guess where it installs on the unibody? I'd guess at the subframe points.
http://cgi.ebay.com/ebaymotors/ws/eB...category=34200
Old Feb 10, 2004 | 06:18 PM
Here is a link to an aftermarket x-brace from lgmotorsports:
http://www.lgmotorsports.com/g2_prod....htm#subframes
Whats interesting is the part where it says, "NOTE: Will not fit convertible models, as they already have built in subframe connectors and an X-brace. "
I know about the built in SFC's....but a built in x-brace? Wonder if they mean "cross" brace or "x"-brace.
Old Feb 10, 2004 | 07:09 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
ive seen the x brace offered for 4th gens from classic and i think pst. converts come with factory subframes and the x wont go in because of the design "i think". makes you wonder what the hell the factory didnt put subs in the t top cars, or all the unibodies even.
Old Feb 11, 2004 | 08:12 AM
I know....it stinks. Although they say that the unibody is stronger than a full frame car.
I started looking into it a bit and I've read in books about the 4th gen convertible. Evidently it wasn't ready in 93 (4th gen verts came out in 94) b/c GM was using a computer model to predict all the major stress points that would be present in a roofless car. They knew that previous gen convertibles were not that stable and corrected it by adding reinforcement in particular areas. Hence the 4th gen vert is the "most rigid camaro ever built". But they never mention exactly what they did to make it that way. I can;t find any specific info about what they did.
Chevrolet built all 4th gen verts (not ASC). So you'd think any added braces/members would be available to at least look at and get an idea of what they did.
I've seen the added frame braces GM used on the C4 verts. They used a huge x-brace along the bottom and three extra side to side reinforcemnets from front to back (a "wonder bar", k-member reinforcement, and a brace that attaches the rear shock towers).
But no one mentions whats been added to the 4th gen verts.
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
GageBrand
Oct 22, 2015 02:30 PM
okfoz
Oct 13, 2015 02:19 PM
