BMR Torque Arm
Old Feb 12, 2004 | 09:38 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
BMR Torque Arm
Just curious if anyone has ever purchased the BMR Torque arm.
I hate to do this to steve spohn, since all my suspension parts and chassis parts so far have been from him, but his Torque arm costs 399.99 shipped to my door while at thunderracing.com, I can get it shipped for under 325.00. :-/
But I was just curious if anyone has any experience with the BMR Torque Arm. Thanks
Old Feb 12, 2004 | 09:44 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
which BMR arm are you looking at, they have 3 diffrent versions.
one that uses a stock style mount
the trak pack, that needs a cross-member welded in
and the extreme, which is a heavier duty versino of the trak pack.
the later two on that list are much shorter than stock, so weight transfer will change, good for drag racing, bad for road racing, auto-x , or anything where braking performance is wanted.
Old Feb 12, 2004 | 11:45 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I am using the first one.
Old Feb 12, 2004 | 12:38 PM
vjo90RS8's Avatar
Car: 2002 Z28
i have the BMR tailshaft mounted torque arm and have had no problems with it. Its a nice part and i would definately recommend it.
Old Feb 12, 2004 | 03:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should you simply be shopping for options and you want something stronger than stock (but non-adjustable), you might consider Edelbrock's version at, I think $159:
https://www.thirdgen.org/techbb2/sho...hreadid=222747
JamesC
Old Feb 12, 2004 | 11:07 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
who sells the edelbrock arm??
Old Feb 13, 2004 | 12:24 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Spohns unit moves it off of the tailshaft though - that's where the price comes in. The torque arm should NEVER have been put ON the TAILSHAFT.
I am sure BMR made improvements to the tailshaft mounting idea though... but I would go with Spohn and save my money elsewhere.
Old Feb 13, 2004 | 04:19 PM
JamesC's Avatar
I purchased my Edelbrock from Summit: EDL-5280.
JamesC
Old Feb 13, 2004 | 06:56 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Spohn also has a new one with the factory tranny mounting point. Think its cheaper then the BMR one.
Old Feb 18, 2004 | 08:06 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
torque arm
i think jegs has a torque arm that also mounts to a welded-in cross brace...thus taking pressure off the trannie.
Old Feb 18, 2004 | 08:45 AM
b-man's Avatar
Car: 91 Z28
Engine: 5.7
Transmission: TH-700-R4
can spohn's torque arm be used with alston's sfc's?
Old Feb 18, 2004 | 05:49 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Yes it can. Just tell Steve when you purchase the arm and he will notch the crossmember for you to clear the alston's.
That' what he offered to do for me, but I forgot to tell him so I notched them myself. Only took a few minutes to do.
Old Feb 19, 2004 | 07:30 AM
b-man's Avatar
Car: 91 Z28
Engine: 5.7
Thanks for the info. Later, b-man.
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
