steering brace??? What's it called????
Old Feb 18, 2004 | 10:27 AM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
What's the real name of that brace you can buy for the thirdgens that stiffens up the frame on which the steering box mounts???? I came across it briefly on a thread about strut tower braces, but I can't remember any specifics. It's supposed to keep the frame rail from flexing when you turn the wheels, for a more crisp response. What's the name of it and where can I go to get one for a reasonable price???
Old Feb 18, 2004 | 10:36 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
its called a WONDERBAR i bought mine through tds and its awsome very good price to and lons a great guy
Old Feb 18, 2004 | 10:44 AM
Car: 1984 Camaro
is there a web address I could try to look at one?
Old Feb 18, 2004 | 10:51 AM
bes217's Avatar
TDS has their link at the top of the page. Spohn, and thunderracing.com, both sell them and their link is at the top as well.
Old Feb 18, 2004 | 12:46 PM
MdFormula350's Avatar
http://www.top-downsolutions.com/
Old Feb 18, 2004 | 02:43 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
What it is called is " STEERING BOX SUPPORT". However; people without much knowledge call it AKA "wonder bar" same people that call a limited slip a posi.
Old Feb 18, 2004 | 03:08 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
you calling me slow? lol jk i used wonderbar so he could find it
Old Feb 18, 2004 | 03:30 PM
Car: 1984 Camaro
Hey, thanks for the link. How do those mount, though? Do they use existing holes or do you have to drill new ones?
If anyone has pics of one on their car, I'd like to see one if you could post it.
Old Feb 18, 2004 | 06:07 PM
vjo90RS8's Avatar
Car: 2002 Z28
they bolt to the the same place the sway bar bushing supports bolt to
Old Feb 18, 2004 | 06:26 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Correct. For some reason my Spohn one had a mounting hole that was off. A few minutes with the dremel solved that. Pretty much you lossen the end links and unbolt the sway bar bushing and let it hange down. You place the wonderbar right up to the holes and bolt the sway bar back on.
Old Feb 18, 2004 | 09:08 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
here's a pic of my homemade/handmade steering brace
Attached Thumbnails steering brace???  What's it called????-steering-brace.jpg
Old Feb 18, 2004 | 09:22 PM
Car: 1984 Camaro
ahhh I see....so this would be a logical time to upgrade the endlinks then, since the old ones are going to have to be busted loose anyway. I didn't realize the installation was going to be that easy. I'll just make sure I soak the bolts holding the sway bar brackets up with a bunch of PB Blaster, to ward off Murphy's Law...
I read on the TDS site that these wonderbars actually improve handling better than STB's do. Is that what you guys found, in your opinions? The steering brace is definitely something I am going to do, but I'm wondering if I'd even notice the STB with the steering brace already on there. The STB I'd be going with would be the 3-point design, only.
Old Feb 18, 2004 | 10:32 PM
91banditt2's Avatar
Engine: 5.7 HSR
the end links do not need to be removed
Old Feb 19, 2004 | 12:28 AM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
ahh! The wonderbar! Not to be confused with wonderbra!
Here's mine that I installed.
Old Feb 19, 2004 | 01:19 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
thats a sweet pic man, looks good in red, i got the powdercoated black one
Old Feb 19, 2004 | 07:04 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It is really not a bad idea. And for as cheap as they are it is added insurance. The stock ones can rot away really easy and you would never know it until you tried to take it out and have it crumble in your hand. It would take maybe 5 exrta minutes of work on top of the wonder bar.
Old Feb 19, 2004 | 07:33 AM
Car: 1984 Camaro
actually it'll be another 20 minutes cuz mine are pretty well rotted and are going to have to be cut (I hate New York's climate ), but you're right. Staying with the stock ones is only going to leave me on borrowed time; who knows when they'll snap. I put urethane bushings and grade 8 hardware in the back end's sway bar links, might as well do the same up front.
WWasem, thanks for the pictures.
I think I'm definitely going to order this thing next payday. I'll be going to Sears to pick up my new electric impact wrench, too...so the wonderbar will give me something to do to try out my new toy...
Old Feb 19, 2004 | 08:05 AM
DJP87Z28's Avatar
The function of the Steering Box Support (AKA wonder bar) and Stuct Tower Brace (STB) are two different things. They both perform two seperate functions.
Simple explainations:
1) SBS ties the front rails together preventing flex from the power steering box. Thats all, It was a quick Gm fix for the bigger tire & wheels. It was standard on IROC's
2) STB helps tie the two shock towers together to prevent lean out or lean in when cornering. This is impoves handling. Note:
most new cars now have this feature.
I will say if your car does not have these, you would be wise to spend the money for them. Both are good options and I have both plus other handling upgrades.
Old Feb 19, 2004 | 09:16 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I've just put the TDS Steering Brace on sale for $42 (normally $50). Available only in gloss black powder-coat at this special price. Here is a link to the TDS Steering Brace GP.
Lon Salgren
Top-Down Solutions
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
punkmaster98
Sep 8, 2015 09:45 PM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
