help with frt coil overs
Old Feb 19, 2004 | 04:40 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I`m trying to figure out what spring I`ll need for the front coil over conversion I have...The kit requires a 10 inch spring...So they sent me 200 pound springs. They really look like a harley spring, Small wire too. My car has over 1000 pounds on each front tire, because of it`s iron headed big block. Pro fab will exchange the springs with anything I need, but really can`t make a recomendation on what poundage I need, any idea`s??
Old Feb 19, 2004 | 06:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: help with frt coil overs
I would take a look over on some 4th gen sits and what size springs they run. What coil over kit do you have? Check out QA1 stuff in jegs or summit. They make some pretty cool coil springs for that that should work.
Old Feb 19, 2004 | 07:57 PM
JERRYWHO's Avatar
I have a Art Morrison kit on my car and have used his springs and Eibachs on the coil over kit.
First some info on your setup.
What will you do with the car. ( drag only, limited street, street-strip or all street )
On the springs you have what is the wire size and number of turns. (coils )
with this info and the post above then I can start to help.
Jerry
Old Feb 19, 2004 | 08:27 PM
my car is used as street/strip, mostly street and the coil over kit is from pro fab racing http://hstrial-vhouse.homestead.com/our_products.html the kit is about half way down, the wire size is about 9/16 dia maybe and I can compress it about 2 inches with my hand...It just feels weak. The conversion provides for ride adjustment, but I think the car is just gonna collapse the springs.
Old Feb 19, 2004 | 10:33 PM
JERRYWHO's Avatar
The reason I asked for wire size and number of turns is so I can calculate coil bind, travel and spring rate. To do this I need the wire size in thousands and the turns.
You are right 200lbs is to low for your car.
If you have 200lbs springs and 1000lbs on each front wheel the spring will compress 5" (200x5) On your springs the coil bind is about 4" ( need the info) Your 10" springs with the load will be 1" from coil bind and thats not enough down travel for a street driven car. Most third gens have about 2 1/2 down stroke and 3 1/2 up stroke.
A 275lbs spring rate spring will compress 3 5/8s and still have 2 3/8s before coil bind.
Jerry
A picture of my car fitted with 12" 150lbs Eibach springs
Terrell351
Jun 13, 2021 01:13 PM
Derick15
Sep 17, 2016 05:28 PM
lt1z350
Aug 28, 2015 05:57 AM
lt1z350
Aug 23, 2015 08:33 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
