rears not grabbing still
Old Feb 21, 2004 | 05:11 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I have a 89 GTA with PBR rear discs. I jacked up the rear end and the brake pedal will not stop my wheels.
1) I adjusted the ebrake, and the ebrake can stop the wheels (barely)
2) I put Speedbleeders on and bled the rear brakes.
3) I have new pads.
4) Fluid flow is good, it squirted out when I bled them.
5) I have to use a C clamp to press the pistons in after I pump the brakes to extend the pistons.
Should I get a caliper rebuild kit?
SHould I also buy new pistons?
Old Feb 21, 2004 | 05:45 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Yep its time for new calipers of some sort. The pistons in my rears corroded and seized once. Just replaced the calipers
and everything was ok again
Old Feb 21, 2004 | 11:53 PM
Car: 89 GTA
Axle/Gears: 4.10
I think calipers are OK
I am not convinced my calipers are bad.
When I have them removed from the rotor and press the brake pedal, the piston comes out and I have to use a clamp to press it back in.
Could my rear portion of the master cylinder not be giving enough pressure to squeeze the rotor?
Old Feb 22, 2004 | 12:20 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That would be a function of the proportioning (combo) valve. What kind of shape are the rear caliper guide pins in? Clean with no corrosion, boots not torn?
hectre13
Dec 11, 2023 08:14 AM
usafirebird
Exterior Parts for Sale
Oct 19, 2017 02:00 PM
IroczFan
Oct 6, 2015 10:13 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
BurlyChev
Aug 22, 2015 01:52 PM
