Bigger rear sway bar?
I was wondering if there is any aftermarket company making a bigger rear sway bar than my stock 90 WS6 bar on the Formula.
i am putting in a 3:73 Posi rear (goodbye 2:73 peg leg!) and i also am installing spohn subframe connectors, lower control arma and panhard bar and was looking at how wimpy the rear sway bar looks compared to the spohn parts.
also the car is autocrossed regularly during the summer so it would obviously benifit it.
Car: 4
Engine: 6
Transmission: 5
Re: Bigger rear sway bar?
Click on the sponsors' links, at the top of the page. That's why they put them there. Steve sells some sway bars. Global West, Ground Control, and a whole bunch of others make and sell them too.
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
if you want a really big, heavy duty swaybar check out the BMR page. they make the biggest rear swaybar on the market. its in the xtreme section.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
no one touched on the point of why just a larger rear bar?
in auto-x especialy that extra oversteer might not let you get back into the power as soon. if you very nasty understeer, that will help, you could also so go slightly less front bar. bigger is not always better with sway bars. you might also want to consider heavier springs, and not just going with a huge sway bar.
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
