suspension help
Old Feb 22, 2004 | 07:07 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
suspension help
well i want to improve my suspension as much as possible without lowering the car. want it to handle really well. i am already planning on ordering spohn SFC sometime next week. will eventually get a wonder bar, new LCA's, panhard bar, new sway bars, i pretty much would like a recomendation on springs and struts/shocks. i want to retain my stock ride highth as i cant sacrifice any more ground clearance.
Old Feb 22, 2004 | 07:15 PM
92MaroRS's Avatar
also recomendtaion on what type of panhard bar, lca's and that stuff.
Old Feb 23, 2004 | 05:20 AM
92MaroRS's Avatar
oh yea. car will live most of its life on the street with some occasional drag strip and road coarse duty.
Old Feb 23, 2004 | 06:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I can't comment on struts and shocks (mine are stock), but check the sig for some ideas.
JamesC
Old Feb 23, 2004 | 09:33 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well if you want to retain your stock ride height than you need to look at WS6, IROC, or moog replacement springs. All will be a little stiffer than stock but will keep your ride height the same. Some BMR or Hotchkis springs will lower you about an 1" and the prokit will go 1.5". The sportlines, Intrax, and drop zones will lower you up tp 2"+. Subframe connectors, panhard bar, strut tower brace and wonder bar should be on your list. They will dramatically increase the handeling of your car even if you keep the stock ride height. As for what shocks to go with? That is up to you to search and find out peoples opinions. You will find that most people go with KYB's for price and overall impromement over stock and others go with Bilsteins, or konis to have the best shock out there.
Old Feb 23, 2004 | 12:38 PM
92MaroRS's Avatar
yea thats what i was thinking. which is better tho? WS6, IROC, or MOOG?
i do plan on getting SFC, Wonderbar, Panhardbar, and a STB. will most likely get those before i do anything spring and shock/strut related. also plan on getting new sway bars. i'm looking at the set spohn has that comes with all the mounting hardware and the 1 5/16" front sway bar and the 1" rear sway bar. how does that sound?
Old Feb 23, 2004 | 12:43 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It sounds great. Your car will feel so different with the stuff you just lsited. As for springs they are all pretty much the same. I would still go aftermarket and drop the car an inch. It will still be very cloe to the stock ride height but you will get that added performance.
Old Feb 23, 2004 | 12:51 PM
92MaroRS's Avatar
not really an option to lower it as i already scrape damn near everywhere i go. if i dont do it just right i scrape coming into my drive way.
Old Feb 23, 2004 | 03:22 PM
92MaroRS's Avatar
will it be worth it to get the adj. stuff? or will the non-adj. stuff work.
will i need adj. lca', panhard bar, and wonder bar?
Old Feb 23, 2004 | 05:23 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If you lower the car than it is necessary to use an adjustable panhard rod to re-center the rear end. An adjustable wonder bar is only for the auto cross **** that wants every last bit of stuff to dial in his car. You really only need adjustable LCA's if you go with an aftermarket torque arm that is not adjustbale. An adjustable torque arm would allow you to use non adjustable LCA's. But it is safe practice to get them if you have any type of torque arm. But, if you are not getting a torque arm anytime soon than non adjustable ones will be just fine.
Old Feb 23, 2004 | 09:19 PM
92MaroRS's Avatar
well i plan on getting the Spohn lca's and torque arm. so i dunno. out of the 4 different lca's they offer which would you recomend for this set up. i will be getting all Poly bushings also.
92MaroRS's Avatar
i also plan on using the relocation brakets to get better traction.
Old Feb 23, 2004 | 09:46 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The relocation brackets are a good choice. As for the LCA's I would stick with the basic adjustable ones. The other ones are beefier units for high powered cars that see a lot of strip action. The basic adjustable ones with poly ends will be best suited for street use.
Old Feb 23, 2004 | 10:05 PM
92MaroRS's Avatar
oh yea might help if i tell ya i plan to add a 383 in about a year.
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
