How do I install front springs?
Old Feb 23, 2004 | 04:41 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I took them out to put the motor mounts on, I kinda did it ghetto since I didn't have a spring compressor at the time and just lifted the car ti'll the spring flew out? I have a spring compressor now and am wondering how I can put it back in, thanks.
Old Feb 23, 2004 | 09:26 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
we actually did mine without a spring compressor. we have one, but it was just being a pain in the neck to use for this application, so we just had one of us push down on the A-arm with our foot, and the other put the spring in. then we lined it up, made sure it was seated properly and finished it up.
granted, i would NOT recommend doing this cuz im sure you'll screw somethin up. although i noticed no adverse effects whatsoever.
Old Feb 23, 2004 | 09:46 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
it was a pain when I did mine for the poly bushings. The easiest way was to compress the spring, attach the ball joint to spindle, seat the spring in a-arm and raise it up with a jack align the bushings with the holes and install bolts. This method is still a pain in the *** but it's the eaisiest way in my oppinion, that or get some lowering springs.
Old Feb 23, 2004 | 11:02 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
When I put my ProKit in I didn't use a compressor. The darn thing was way to hard to use so I said screw it.
I got the car up as high as I could on the stands, put the jack under the a-arm, and then unbolted the strut. Next I lowered the jack slowly until the spring was fully uncompressed. Pulled the stockers out, and put the eibachs in. Jacked it back up into place, stopping everyonce in a while to make sure it was sitting right up in the hole. Did both sides this way and worked great for me. May not be the "recommended way" but it works...
Old Feb 24, 2004 | 07:41 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Here's my step by step guide of how to do it:
http://f1.pg.photos.yahoo.com/ph/tar...m/taramiller72
HTH..Ed
Old Feb 24, 2004 | 11:03 PM
pasky's Avatar
That helped quite a bit, thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TA8487
Aug 11, 2015 09:02 PM
