how many people are running double sperical rod ends??
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
How many people here are running double sperical rod ended suspension components in there cars?? How bad is the noise level?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I used to. It sounded like a box of loose tools in the hatch. Switched over to poly/rod combo and its quiet.
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
I have rod ends on my LCAs, PHR, and TA as well as GW del-a-lums up front and spohn's strutmounts- all are quality rod ends. I also run an 800/150 spring combo with Koni sports. On decent roads the car is smoother than a cadillac but if the road is rutted the car sounds sounds like it's going to fall apart.
My suggestion is that if the roads in your area are well maintained, than besides the regular inspection requirements for rod-ended equipment, you will have a better ride than with urethane.
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I also have sperical rod end suspension (lca, ta, ph) and as james said on good roads its just fine. But once you start hitting bumps its not so nice after that O_o
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Come up here justins86bird....its amazing how smooth salt and snow makes a road....thats the only i don't like about cleveland...winter f's the roads up bad.:lala:
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
I have all rod end suspension....I have TEFLON EXPENSIVE rod ends...Not the cheap ones that most suspension stuff comes with....Anyway Mine makes no more noise than Stock...EXCEPT...You can hear a little Gear whine from the rear with the solid versus No noise with the Rubber...If you get teflon lines Good Quality rod ends then they wont rattle around like cheap ones do..
Car: check
Engine: check
Transmission: check
Originally posted by grafx
like the ones that Spohn now offers on their suspension components??
RBob.
92camaroJoe
Aug 13, 2015 06:07 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
