rear is too low
Car: Z28
Engine: 310
rear is too low
My cars stance does not look right, back end looks too low and I want to raise it, so I did a search on air shocks and found out they are bad because they blow out the mounts. So I need to know what I have to do to get my back end to sit higher.
Thanks,
Joe
Thanks,
Joe
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your springs are shot and time for replacement. With stock wheels and tires you should have 2"+ of fender gap with tstock springs.
Car: Z28
Engine: 310
Is there any springs that would be higher than the stock height? I have dual exhaust and I plan on getting bigger tires so I think it'd be good to have it a little bit higher
What size tires do you have on there right now? You might actually gain the height you need just by swapping to a taller tire. Also, have you thought about lowering the front of the car like an inch or 2?
Car: Z28
Engine: 310
and I dont really want to lower to front because my exhaust would probably scrape. I just need to know if there is a heavier aftermarket spring. I was looking through a Jegs magazine and found these bags that adjust ride height and they're only $60. Anyone ever try these?
Car: '90 RS
Engine: 377 LSX
Originally posted by 1986camarojoe
235/60/15
235/60/15
Car: Z28
Engine: 310
Would I just be able to get new springs at Advance or would I have to order something? Also, I do have longtubes and my mufflers are like right under the seats.
Car: '90 RS
Engine: 377 LSX
www.gmpartsdirect.com
www.yearone.com
You could also get factory ones from the site sponser up top.
If you want to go the aftermarket route you can check out the site sponsers at the top of your page or flip through summit or jegs.
kah992
Aug 19, 2015 02:55 PM
novaderrik
Aug 10, 2015 12:44 PM
