caster adjustment
Old Feb 28, 2004 | 02:10 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
caster adjustment
here are pics i took yesterday. some people have asked how do you adjust caster when the slots on hte mount go left right. it's because the slots for caster are built into the tower.
Old Feb 28, 2004 | 02:11 PM
mrr23's Avatar
Engine: 360 HSR
and from the bottom
Old Feb 29, 2004 | 08:11 PM
25THRSS's Avatar
good pics, but I still don't understand. When you bolt the shock back up don't you have to put it through the center of the mount meaning the adjustment is lost?
Old Feb 29, 2004 | 08:44 PM
mrr23's Avatar
Engine: 360 HSR
when replacing struts only, you do not loose adjustment. only if you replace the strut mount, then you loose the adjustemnt. but what you can do is scribe around the strut mount with a marker or pencil. then when you reinstall the new strut mount, it will be real close.
Old Mar 9, 2004 | 06:02 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
There is now another choice for a bunch more adjustment...
Jason
Old Mar 9, 2004 | 06:11 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
holy cow man, thats cool, where did u get those spacers?
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
