Steel Braided Brake lines to replace the Steel line?
Subscribe
Mar 5, 2004 | 08:21 PM
is there such thing? i know summit has bulk steel braided line that they sell and the fittings.. i was wondering has anyone tried this??
i was installing the earls lines that replace the shabby rubber ones, and i snapped the brake line in the rear from the master cylinder. i spent 8 hours trying to bend tube to make it work and i just said **** it...
so does anyone know where i can get hose? is there any precut stuff?
Reply 0
Mar 6, 2004 | 12:22 AM
The braided steel line is flexable. You don't want to replace your whole steel hardline with that.
Reply 0
Mar 6, 2004 | 12:39 AM
Why not snag the hard lines from a junkyard car?
Reply 0
Mar 6, 2004 | 01:30 PM
cause chances are the junkyard car is rusted all to hell... whats the point of using rusty *** lines to replace rusty *** lines?
Reply 0
Mar 6, 2004 | 05:21 PM
more then likely only the outside has some surface rust and not the inside. I would rather put a hardline then to replace it with a braided line. Your rear brakes are probably gonna get a little weaker also if dont use the hardline. Extremely weaker?...maybe not but there will probably be a difference.
Reply 0
Mar 6, 2004 | 05:47 PM
Quote:
Si!
To answer your original post, I do not believe that a ss braided is a good replacement for hard lines (ala Justin). Particularly if this is the main trunk coming from the master cylinder (is this the case?).
I would check inlinetube.com or similar. I know they offer ss hard line, I think they may even offer stock lines as well. They are around $155 (OEM) to $180 (SS) for a set. From my own experience, make sure they get the thread pitch correct. There are other suppliers: classictube.com and so on.
If your stock line broke, it might be an indicator of trouble to come. Maybe time to replace them all? I can't tell without seeing them.
Anyway, with new hardlines and the Earl's, you should feel some difference over stock.
Best-
S-D
Reply 0
Mar 6, 2004 | 09:01 PM
If the lines have brake fluid in them there wont be any rust at all.
Reply 0
Mar 7, 2004 | 02:47 PM
well... then i guess im gonan check the prices of local brake shops to see how much theyll charge to put new hard lines in for me...
in the mean time ill put a plug in the single line that goes back to the rears, just os i can drive it to the brake shop.......
Reply 0
Mar 7, 2004 | 03:13 PM
i just went to the Inlinetube.com place and it looks like i may go with them...
their stainless steel lines are only like 180, and its a 7pc set????
i dont get that....
2 for the front,
one from the master to the rear axle
then from the middle of rear axle to each wheel
thats... only 5???
wheres the other 2?
Reply 0
Mar 7, 2004 | 04:04 PM
I think:
2 from the MC to the prop. valve.
2 from the prop valve to each front disc.
1 from the prop valve to the rear (rear main trunk).
2 to each of the rear wheels.
=7.
Make sure they get the threads right, particularly with the ones that go from the MC to the prop. valve.
S-D
Reply 0
Mar 7, 2004 | 07:25 PM
they said the threads for the car are exact to what the factory had... pretty good deal imho
Reply 0
Subscribe
