10 bolt axel tube welding
Old Mar 9, 2004 | 12:58 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
I heard the axel tubes on the 10 bolt should be welded where they meet the center section to make the rear housing stronger. I already re-built the rear with an eaton posi, moser 28 spline axels, 3.73 ring and pinion set, and a T/A diff girdle. I want to make this rear as strong as it can get, so will this really make a big difference in strength? also can this be done with the rear all together? or do the axels have to be pulled and all that crap? I would hate to ruin those nice new (and pricey) axels by welding those up. some body please clear this up
Old Mar 9, 2004 | 01:00 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah i wanna know also. id like to do this with my rear but im not sure if you have to drain the fluid first or do anything.
Old Mar 9, 2004 | 01:06 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I dont see why it would hurt, and I would think it would be okay with everything in the axle. However, I doubt it would make the axle all that much stronger. I think most of the time when someone breaks a rear end, its usually just shearing teeth off the ring gear, or splines off the axles.
Old Mar 9, 2004 | 01:18 AM
1992rs/ss's Avatar
see I was told that with a quality parts rebuild the the thing that kills a 10 bolt is either the axel tubes flexing because they are a smaller tubing (welding makes housing stiffer) and that the diff has a tendency to start walk under hevy load (the reason for the girdle with the pre-loads)
Old Mar 9, 2004 | 04:56 AM
ede's Avatar
ede
weld the tubes and a braced cover is suspose to add 40% strength to the rear. i've welded rears without draining them, but i think i'd drain it.
Old Mar 9, 2004 | 10:40 AM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/t...nguprear.shtml
http://www.ws6transam.org/10bolt.html
its a great idea to weld the tubes since they seem to be only tac welded from the factory. i would be safe and drain the fluid because that rear end will get hot.
when i did relocation brackets where the lower control arms that whole side of the rear ned u can see change color from the heat.
i am going to try and maybe one day use an arc welder my friends has and see what it will do.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
