Wonderbar
Old Mar 15, 2004 | 07:47 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Wonderbar
I just bought a wonderbar today from TDS. Anyone else have this mod. Is it easy to install. I can't wait to get mine and have it installed.
Old Mar 15, 2004 | 08:22 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
yes I have
fairly easy to install. Leave swaybar end links attached, and possibly a friend to help hold the swaybar while bolting up the wonderbar.
Old Mar 15, 2004 | 08:38 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
nah its the simplest thing to do in the world, just unbolt the sway bar brakcets (not endlinks) unbolt a few bolts from the fram slide it in and bolt it up, take literally 15 min. while your at it might as well upgrade those old rubber bushings with poly swaybar bushing , a very cheap and nice mod
Old Mar 15, 2004 | 09:25 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yup just it is just as easy as those guys described. You may want to loosen the end links a bit but you do not have to remove them. Just watch out that the sway bar does not swing down and hit you in the face. It is heavier when you are laying down
Old Mar 15, 2004 | 11:40 PM
25THRSS's Avatar
it woulda been easy if the owner before me hadn't wrecked it :lala: But that's all fixed now.
Old Mar 16, 2004 | 12:26 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
No kiddin, I learned the hard way
Old Mar 16, 2004 | 05:54 AM
MdFormula350's Avatar
great piece, easy mod to install. supports that area nicely.
Old Mar 16, 2004 | 02:04 PM
CaysE's Avatar
What everyone else said. Including the whacking in the face part.
Old Mar 16, 2004 | 07:18 PM
ThraxXx's Avatar
Poly bushings? wonder if I can get these from TDS as well.
Does this Wonderbar do the same thing as a STB?
Old Mar 16, 2004 | 07:22 PM
CaysE's Avatar
It is similar to a STB in that it reinforces the frame, however it does not perform the exact same function. STBs are for keeping the front frame from flexing inward when the suspension gets loaded. Wonderbars are for tighter steering response and preventing the sheet metal holding the steering box from ripping; a common occurance on our aging cars.
Do a search on "wonderbar" or "steering brace" and read. There's a lot of info.
Old Mar 16, 2004 | 08:09 PM
ThraxXx's Avatar
Would a STB still be a wise purchase?
Old Mar 16, 2004 | 08:27 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yes. My car feels amazing with the 3pt edelbrock unit. The front ends on these cars can twist quite a bit. Just a simple set of SFC's and a STB can wake up a lame handeling 3rd gen.
Old Mar 16, 2004 | 10:04 PM
ThraxXx's Avatar
I tried ordering the Edlebrock 3pt STB however the company I ordered it from wanted a photocopy of my visa card. I didn't feel that this was a safe thing to do so I declined the order. I need to find me a company that sells that product and ships to Canada
Old Mar 16, 2004 | 10:09 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
www.jegs.com
Thats all you need to know.
Old Mar 16, 2004 | 10:52 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
I actually just ordered my TDS wonderbar last week, should be here tomorrow and getting installed tomorrow also. I also ordered Spohn's poly sway bar bushings to help that all out too, and i'll likely do a STB in the next few weeks (I'm in steering and suspension class, and I like to work my car out in every area while i'm in each class, so I got 6 more weeks to get my suspension all done out!!)
Old Mar 17, 2004 | 06:11 PM
CamaroEFI's Avatar
i have it...it did make a difference in the handling. the whole front of the car feels tighter during sharp turning. i also have the tokico struts and shocks so that helps too
Old Mar 17, 2004 | 07:04 PM
Stingraye's Avatar
Car: 1986 Trans Am
where'd u get u'r tokoiko shocks and struts from, and how much did u pay?
Old Mar 18, 2004 | 06:41 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Yea I got the wonderbar from TDS and it tightened up my steering nicely.
Old Mar 18, 2004 | 07:31 PM
MCas7's Avatar
I got mine and installed it, but I guess I don't drive hard enough to notice a difference. I'm still glad I got it. I like the added security.
Old Mar 18, 2004 | 11:45 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
I did not notice any difference when I put mine on however the idea of more support is great
Old Mar 18, 2004 | 11:47 PM
Stingraye's Avatar
Car: 1986 Trans Am
installed mine yesterday with new poly swaybar bushings, tightened up the body roll and steering response a lot, she handles a lot better.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
snakeshooter
Sep 10, 2015 07:46 AM
toosloz
Carburetors
Dec 12, 2001 12:02 PM
