stainless steel caliper banjo bolts
Old Mar 20, 2004 | 05:03 AM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Anybody know of any sources for the above mentioned banjo bolts?
Thanks.
Andy.
Old Mar 20, 2004 | 11:42 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Earls:
Earl's Home Page
Earl's Banjo bolts
Old Mar 21, 2004 | 07:05 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Just curious: Why would you want SS bolts here?
Ed
Old Mar 21, 2004 | 08:19 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
Ed
What else would you use? No one makes regular steel brake fittings, and no one makes aluminium banjo bolts.....not strong enough. Threads subject to stripping due to force necessary to seal crush washers.
All brake adapters and fittings are normally SS, due to the pressures involved in the system and to prevent corrosion.
Old Mar 21, 2004 | 11:32 AM
Car: 91 camaro rs
Correct!
And, the most important reason,................they can be polished up to look real good! Everything else under the car is polished or plated, so why stop at banjo bolts!
Thanks Chickenman35. Off topic here, but I have been reading your ported/non ported vacuum postings, and all your carb rejetting/tuning posts. :hail: :hail: :hail: :hail: :hail: Wow, what an expert. Your advice has even got to the UK! I recently received from Summit their Crane adjustable vacuum can and centrifugal weights for my HEI dizzy. Thanks for all the advice and recommendations via the forums. Very, very impressive.
Andy.
Old Mar 21, 2004 | 08:25 PM
ebmiller88's Avatar
I just use the GM stuff, just wondering if there was any "odd" reason for requesting SS bolts here. Thanks for the info!
Ed
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
SG91camaro
Sep 5, 2015 10:27 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
