brake swap
Old Mar 21, 2004 | 06:14 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
brake swap
can brakes off a corvette be put on a 86 z28? if so, is it just the calipers or can the rotors be used also? and what yr corvettes could these parts be taken from?
Old Mar 21, 2004 | 06:31 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i know for sure you can use c4 stuff, i think ive seen people using c5 stuff
Old Mar 21, 2004 | 06:33 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
they would be goin under 15X 9.5 rims...if that makes a difference
Old Mar 21, 2004 | 08:21 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
To answer your question, yes...both the C4 standard and C4 HDs will fit, I've made them both work. If you have 15" wheels, the standard C4s are your only option. The 13" HDs and the C5 brakes will require 16 and 17" wheels respectively.
Ed
Old Mar 21, 2004 | 11:09 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
so those could be breaks off of ANY C4 vette? or is it only certain models?
Old Mar 22, 2004 | 05:55 AM
ebmiller88's Avatar
Standard C4 brakes need to be from a '88-94 model. All brakes were HD from '95-96.
Ed
Old Mar 22, 2004 | 10:10 AM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
do they bolt right up, or do they need some fabrication or an aftermarket bracket?
Old Mar 22, 2004 | 10:27 AM
ebmiller88's Avatar
Yep, you'll need some fab work, this isn't a bolt on thing exactly, but it can be. A few guys on the boards including myself can do the custom stuff. You'll need the spindles, custom brackets, and hubs made, and then all the brake parts. Also longer studs for the hubs.
Here's my current setup on my 1991 RS. Let me know if you have any questions:
https://www.thirdgen.org/techbb2/sho...ghlight=yessir
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
