struts or LCA's?
Old Mar 27, 2004 | 11:26 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
struts or LCA's?
ok a while back i posted about my mad wheelhop at the track. well i have come to the conclusion im gonna replace my suspension on the car, struts, lca's and springs. but i want to cure that wheel hop first, so what would most likely be the cuplrit, the struts gone bad or LCA's?
Old Mar 27, 2004 | 12:58 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Wheel hop is cause by the inability of your shocks to control your springs from the bouncing effect put on it by the tires. This is a dampening issue and lower control arms, relocation brackets, and shocks will go a long way and will cure the problem.
Old Mar 27, 2004 | 01:15 PM
MdFormula350's Avatar
yup rear shocks and lower control arms should solve any wheel hop at all and to further make it better lca relocation brackets.
MUST MODS.
Old Mar 27, 2004 | 01:38 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
but since im on limited funds, which ones first? lcas and then struts or struts then lcas? i can buy one set this month and buy the other next month.
anyone have anything against spohn products? i want the adjustables since i will be buying lowering springs as well soon here.
Old Mar 27, 2004 | 06:33 PM
Kandied91z's Avatar
i like my kenny browns....they've been out alot longer and are cheaper as well as they are chromoly too.
if i were you since your on a budget i'd go with what will offer the most gain. shocks/struts/springs effect everyday use. lca's can wait. just box your stock ones if your on a budget.
Old Mar 27, 2004 | 11:34 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
im not really on a budget, just only limit myself to one thing a month.
i think i will purchase some struts first. i found some 3 way adjustables for 40 bucks each. next month ill get the LCA's
Old Mar 28, 2004 | 12:39 AM
the rear's are shocks, the fronts are struts.
i changed my shocks first when i had wheelhop, it didnt really go away as far as i could tell. but on my first car i had a bad tranny mount also. so having massive wheel hop and a bad tranny mount it makes the car seem likes it falling apart.
so on my next car after i fixed the tranny mount, i did lower control arms first and "wheel hop" mostly went away.
so either way u go ur helping performance.
lower control arms are easier to put in unless the bolts are rusted on good.
Old Mar 28, 2004 | 12:49 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ooh u mentioned tranny mount?
it just so happens that a few days before the racetrack where i discovered wheel hop was horrible, is when i installed my energy suspension tranny mount.
*** it sucks, my old stock replacement one wore out within only 3 months, but even with it ripped, i didnt get wheel hop at the track. maybe this peice of crap aftermarket one causes the problem?
opinions?
Old Mar 28, 2004 | 03:02 AM
Kandied91z's Avatar
don't like them........good ol rubber for me. however now that i have alot more power i really need it unfortunately.
Old Apr 2, 2004 | 05:26 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
I like my Spohns. 4130 Cromo w/poly bushings. I could immediately feel the difference launching, stopping, and in the corners.
Old Apr 2, 2004 | 09:03 PM
CaysE's Avatar
The ripped tranny mount was giving you less wheel hop cause your power was compromised at the tranny. With the poly trans mount, you're putting the power where it's supposed to go... to the wheels. Now you need to upgrade the LCAs, shocks and springs to get even more of the power to the ground.
Basically, the trans mount didn't cause you a problem, it just made an existing problem apparent: weak rear suspension.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
