cragar street star backspacing
Old Apr 6, 2004 | 10:22 PM
sbchevyz28's Avatar
hey i am looking at some 15x10 cragar street stars for my 83z and i have a set of 275/50/15 bfg radials, and was wandering what kind of backspacing i would need to put those on without rubbing. thanks for any imput you might have
Old Apr 7, 2004 | 07:21 AM
crate28's Avatar
Car: 84 Z28
Engine: ZZ4
Transmission: 700R
Crager Street Stars
Hey - I have the same tire on a 15 x 8" in the rear of my '84 and it did rub at first with no spacer. I had to replace my rear original coils (125,00 miles) and that did the trick. I don't believe that wheel has any backspaceing options.
Old Apr 7, 2004 | 02:15 PM
sbchevyz28's Avatar
so do you think i could get it to fit, might i have to get a hammer, or a sawzawl, back there to make em fit, or maybe a wheel spacer
Old Apr 7, 2004 | 03:22 PM
crate28's Avatar
Car: 84 Z28
Engine: ZZ4
Transmission: 700R
Like I said before. The factory does not offer a backspacing option on that wheel. Besides it sounds like you already have the wheels. They all fit the inside of the wheel well the same if it is a 8" or 10". The extra 2" in your case would make the wheel stick out (away from the car) 2 extra inches beyond mine. And, mine stick out of the wheel a bit more than I would like with the exact same tire you have. The new coils did the trick for me but if you have power tools and want the wheels bad enough ,....I suppose you could do some cutting. I wouldn't but its your call. If you have lowered it at all, I wouldn't even attempt those wheels. Maybe someone can explain "backspacing" better than I but I know there is nothing you can do to INCREASE the backspacing of these wheels. You need to find wheels with some backspacing options and even then, 10" is alot of wheel.
Old Apr 20, 2004 | 08:27 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
Hey man, I just got my Cragar street stars 15x7 today. They are magnificant!
cheesehomer
Dec 31, 2015 08:48 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
rb85TA
26
Sep 14, 2015 10:29 PM
