OEM 16 inch wheels
Old Apr 9, 2004 | 05:41 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
OEM 16 inch wheels
I have a question regarding a OEM 16 inch wheels (not the GTA wheels).
I have a 1986 T/A with 10 bolt and drum brakes. I heard somewhere I needed a spacers if I wanted to use those wheels. Is it right?
Jon H.
P.s. I tried the search but could not find anything about this
Old Apr 9, 2004 | 01:34 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
TTT:lala:
Old Apr 9, 2004 | 02:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No spacers are necessary. The wheels just bolt up. Assuming they're 85-92 16" wheels, that is. 93-up ones will require spacers.
Old Apr 9, 2004 | 02:59 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Thanks a lot
Old Apr 9, 2004 | 03:09 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
GM put .187 Thick spacers on cars with Iron Drum Brakes using the 16" wheels to keep the same spacing as cars that had Aluminum Drums. My 87 IROC had them with the Drum brakes. No big thing if you don't have them.
Old Apr 9, 2004 | 03:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
.187" = a little less than 5mm..... that's pretty thin.... hard to figure why the factory put such a thin thing there. Must have had something to do with automated assembly line equipment, would be my guess. Alot of people leave them out with no ill effects.
Old Apr 9, 2004 | 04:30 PM
DJP87Z28's Avatar
IT was the difference between the old Alumunum drums and the later Iron drums, so GM made everything equal with the .187 thick spacers when they started using the 16" Aluminum wheels.
Who knows what GM did in later years. My guess is as a cost savings they did away them with also. Sold mine when I changed over to rear discs.
Old Apr 10, 2004 | 07:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some cars with disc brakes also have the spacer.
JamesC
Old Apr 10, 2004 | 01:42 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Thanks for all the replies
morrow
Jan 13, 2024 12:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
