spohn panhard not ligning up
Old Apr 11, 2004 | 11:17 PM
LeftTurn1LE's Avatar
I took out my factory panhard in like 2 minutes. The holes on the Spohn bar aren't ligning up. I thought if I moved the differential up and down that would help since one end is attached to the axle. Any other ideas?
Old Apr 12, 2004 | 01:00 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
how far off is it? you have the rear end suspended in the air right? might help to have someone push on the appropriate side to line the bolts up.
Old Apr 12, 2004 | 01:34 AM
I got it. I guess the rear just shifted a little even though I had it supported by the jack. It just needed to move less than a 1/4". I was gonna put in my lca's tonight too, but I need a different socket and Sears was closed today.
Old Apr 12, 2004 | 05:39 PM
nolanr0413's Avatar
Car: Trans am
why didnt u get an adjustable panhard bar?
Old Apr 12, 2004 | 10:11 PM
Cause the non adjustable one is cheaper, and I'd probably just mess something up if I started adjusting stuff anyway.
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Is there really a need for an adjustable one?
Old Apr 13, 2004 | 12:09 AM
EvilCartman's Avatar
Car: '82 Z28
Yes, when you lower the car it'll shift the rear to one side. Using an adjustable one you'll be able to move it back to center.
Old Apr 13, 2004 | 02:14 AM
vjo90RS8's Avatar
Car: 2002 Z28
yeah, when i installed all my suspension parts my rear was shifted to one side and my adjustable panhard bar helped to correct this.
Old Apr 13, 2004 | 11:41 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yeah, but if you have no plans or intention to lower the car, what benefit (or need) is there to the adjustable panhard and LCA's?
Have a Great Day!!!
- Vern
Old Apr 13, 2004 | 02:11 PM
I'm lowering with those Eibach springs though. Hopefully it won't be too bad, only 1.5" drop.
Old Apr 13, 2004 | 02:13 PM
vjo90RS8's Avatar
Car: 2002 Z28
i put on Eibach springs and the new GM thicker isolator and my car's ride height didnt change too much and the rear end was still shifted about a 1/2 inch to one side
Old Apr 13, 2004 | 05:12 PM
Engine: L69
Transmission: A4
I have the Hotchkis 1" lowering springs, so would that have affected the alignment at all?
Old Apr 13, 2004 | 08:10 PM
Well I got the panhard and lca's all in. I didn't really notice any difference, but I guess I wouldn't under normal street driving.
Old Apr 14, 2004 | 05:29 PM
Engine: L69
Transmission: A4
I noticed the potholes and normal bumps in the road are a lot nicer and no where near as harsh. But now, I can definately feel a TON of bodyflex that is just driving me insane! But since Im getting an IROC or Z28 soon, i'll just have to live with it...
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
meeklay812
Oct 1, 2015 03:46 PM
